replace powered by ESRI
16669
70
07-22-2010 02:01 AM
NatashaManzuiga
Hi all I perfectly replaced ESRI logo with this script:
http://forums.esri.com/thread.asp?t=287497&f=2421&c=158#912795
Now how can I replace link to esri.com/flex?
Naty
deleted-user-rQoEFM5qzbHE
When I try to use our logo, I get an error message when building the application:
unable to resolve 'assets/images/NEW_ITRE_LOGO1.png' for transcoding
Can anybody tell me what this error means? Thanks.
RobertScheitlin__GISP
Jeremy,
    Don't take this to hard; But are you thinking before you post questions...? Do you have that image on your system? It simply means you don't have NEW_ITRE_LOGO1.png, as that is a image that is specific to Joshua.
Jeremy,
   Check in the bin-debug folder and see if assets/images/NEW_ITRE_LOGO1.png exists there.
Yeah, it is in the debug/... folder. And, just to make sure it I could view the image I double clicked it to open and it is there and correct.
Jeremy,
     This is a strange issue you are having... Can you attach the logo? Maybe there is some actual issue with it's encoding that Flex is having an issue with.
Here it is.
Also, do you know where I can define a new location for the overview map widget? I have been looking around and can't seem to find which file has the code that specifies the location.
Thanks.
Jeremy,
    On the Logo Issue, I was able to add your logo to my project (unchanged) and have it run just fine showing your logo... I am really not sure where you are going wrong.
   On the overview map location question, to move the overview map widget you would have to rewrite a lot of code in the OverviewMapComponent.mxml to change the location. This is one widget that is really not meant to be moved.
Yeah, that's weird. I have no trouble pluggin in another .png file found in the assets/images folder. Maybe I will try and delete it and add it again. Maybe something got corrupted when I added it the first time.
Thanks again for all your help.
JoshuaCoates
Jeremy, ok I am on the same page as you. I just thought there was something else I was missing. My MapManager.mxml is set up like yours. And my logo works fine and I do not see the ESRI logo at all, but yes both my link and ESRI opens at the same time. We were getting much forum love on this at first, but it seems as if people are not sure as to why both links would still open?! I guess its better than nothing that my logo is there and my link opens, just dont really need to ESRI link to open with it.
