replace powered by ESRI
16661
70
07-22-2010 02:01 AM
NatashaManzuiga
Hi all I perfectly replaced ESRI logo with this script:
http://forums.esri.com/thread.asp?t=287497&f=2421&c=158#912795
Now how can I replace link to esri.com/flex?
Naty
RobertScheitlin__GISP
Joshua,
   To add code boxes click the # button on the buttons above the window where you type.
JoshuaCoates
<?xml version="1.0" encoding="utf-8"?>
// Copyright (c) 2010 ESRI
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/License.txt
<s:SkinnableContainer xmlns:fx="http://ns.adobe.com/mxml/2009"
                      xmlns:s="library://ns.adobe.com/flex/spark"
                      xmlns:mx="library://ns.adobe.com/flex/mx"
                      creationComplete="init()"
                      height="100%"
                      skinClass="com.esri.viewer.skins.MapManagerSkin"
                      width="100%">
    <fx:Metadata>
        [ResourceBundle("ViewerStrings")]
    </fx:Metadata>
    <fx:Script>
        <![CDATA[
            import com.esri.ags.Graphic;
            import com.esri.ags.Map;
            import com.esri.ags.SpatialReference;
            import com.esri.ags.TimeExtent;
            import com.esri.ags.events.DrawEvent;
            import com.esri.ags.events.ExtentEvent;
            import com.esri.ags.events.FlareEvent;
            import com.esri.ags.events.FlareMouseEvent;
            import com.esri.ags.events.GraphicEvent;
            import com.esri.ags.events.LayerEvent;
            import com.esri.ags.events.MapEvent;
            import com.esri.ags.geometry.Extent;
            import com.esri.ags.layers.ArcGISDynamicMapServiceLayer;
            import com.esri.ags.layers.ArcGISImageServiceLayer;
            import com.esri.ags.layers.ArcGISTiledMapServiceLayer;
            import com.esri.ags.layers.FeatureLayer;
            import com.esri.ags.layers.GraphicsLayer;
            import com.esri.ags.layers.Layer;
            import com.esri.ags.layers.supportClasses.StaticLayer_m_esriLogo;
            import com.esri.ags.layers.supportClasses.StaticLayer_m_globe;
            import com.esri.ags.tools.DrawTool;
            import com.esri.ags.tools.NavigationTool;
            import com.esri.ags.virtualearth.VETiledLayer;
            import com.esri.viewer.AppEvent;
            import com.esri.viewer.BaseWidget;
            import com.esri.viewer.ConfigData;
            import com.esri.viewer.IInfowindowTemplate;
            import com.esri.viewer.ViewerContainer;
            import com.esri.viewer.components.InfoPopup;
            import flash.utils.setInterval;
            import mx.collections.ArrayCollection;
            import mx.containers.Canvas;
            import mx.controls.Alert;
            import mx.core.UIComponent;
            import mx.events.CloseEvent;
            import mx.resources.ResourceManager;
            import mx.controls.Image;
            import spark.components.Group;
            /* skin section */
            [SkinPart(required="false")]
            public var managerView:Group;
            public var map:Map;
            [Bindable]
            public var mapLeft:Number = 0;
            [Bindable]
            public var mapRight:Number = 0;
            [Bindable]
            public var mapTop:Number = 0;
            [Bindable]
            public var mapBottom:Number = 0;
            [SkinState("decorated")]
            [SkinState("resized")]
            [SinkState("normal")]
            private var configData:ConfigData;
            private var defaultstatus:String;
            //[SkinPart(required="false")]
            private var infoPopup:InfoPopup;
            private var navTool:NavigationTool;
            private var drawTool:DrawTool;
            private var drawEndFunction:Function;
            private var fullExtent:Extent;
            private var _manManagerSate:String = "resized";
            private var proxyEnabled:Boolean = false;
            private var optLayerTable:Array = new Array();
            //[Embed(source="assets/images/i_bartow.png")]
            private var myLogo:Class;
            private function changeESRILogo(map:Map):void
                for (var i:int=0; i<map.staticLayer.numChildren; i++){
                    var component:UIComponent = map.staticLayer.getChildAt(i) as UIComponent;
                    if(component.className == "Image"){
                        var img:Image = component as Image;
                        if (img.source.toString().indexOf("logo") > 0){
                            img.source = myLogo;
                            img.addEventListener(MouseEvent.MOUSE_DOWN ,gotoMyURL,false,1000);
                            return;
            private function gotoMyURL(evt:Event):void
                var myURL:URLRequest = new URLRequest("http://www.bartowga.org/gis/index.html");
                navigateToURL(myURL);
                evt.stopPropagation();
            //init
            private function init():void
                ViewerContainer.addEventListener(AppEvent.CONFIG_LOADED,        config);
                ViewerContainer.addEventListener(AppEvent.SET_MAP_NAVIGATION,   changeNavigationbyMenu);
                ViewerContainer.addEventListener(AppEvent.BASEMAP_SWITCH,       basemapMenuClicked);
                ViewerContainer.addEventListener(AppEvent.SET_MAP_ACTION,       enableMapAction);
                ViewerContainer.addEventListener(AppEvent.SHOW_INFOWINDOW,      widgetShowInfo);
                ViewerContainer.addEventListener(AppEvent.MAP_RESIZE,           resizeMap);
                ViewerContainer.addEventListener(AppEvent.DATA_OPT_LAYERS,      sendOptlayers);
                ViewerContainer.addEventListener(AppEvent.MAP_LAYER_VISIBLE,    changeLayerVisible);
            protected override function partAdded(partName:String, instance:Object):void
                super.partAdded(partName, instance);
                if (instance == map)
                    map.zoomSliderVisible = false;
                    map.addEventListener(MapEvent.LOAD, mapLoadComplete);
                    changeESRILogo(map);
Joshua
   Uncomment this line
should be
JoshuaCoates
Good deal! I have the new image, however, it still is linked to ESRI's web page?!
deleted-user-rQoEFM5qzbHE
To coalesce everything into one post, here is what I did (based on Robert's help)
Added the following lines of code to the 'import' section:
Then I added the following lines, just after the last 'private var...' line.
[Embed(source="assets/images/NEW_ITRE_LOGO1.png")]
In order to get the above to work properly, I had to add a semi-colon to the end of the following line, and then an extra vertical space.
Next, I added the following function (for version 2.0):
                            return;
Now, instead of making the call to the partAdded function from the gotoMyURL, I made it from the mapLoadComplete function.
I think that is everything I did, if I left something out let me know. If I can be of any further help, also let me know since this is pretty fresh in my memory.
JoshuaCoates
That is everything I have done....I have my image showing up, it is still linking me to the ESRI web page though. I have my url in the:
and my call is from:
any reason why my web page wont link the the image?
I am kind of having an issue with that as well. Once I click on the link, our website opens. Then, ESRI's website opens in a new window. So, they both open but there is only one link showing in the code.
JoshuaCoates
Also, is there any reason why after making these modifications to the MapManager.mxml that my OverviewMap in the lwoer right would get messed up? When I click it...it pulls up and is shaded pink...and if you move around in it...it moves the actual map instead of just going to the area? But when I am zoomed in the map...it works as it is suppose to? I dont know if this could have to do with me creating caches for my maps yesterday...and I have not recreated the services for them yet?! SO i know some other things have gone out of whack since I created the caches. (i.e. if you open a layer in the Layer List widget...there are no longer check boxes to turn sub layers on or off)
JoshuaCoates
Yes, that is what mine is doing as well. Both my website and the ESRI website opens. ?!
Joshua,
I don't know that there is an issue with the Overview map. Mine does the same thing, and I guess that is what I thought it was supposed to do. But, since I didn't mess with it before making all these changes, I don't know what it did before.
Regarding the issue with no sub layers showing up next to a map service in the layer list if that happens for us, it usually means that the server has most likely gone down. I usually check and refresh and the option to add sub layers comes back. It doesn't seem like an issue with the code as much as it is with our server (at least in our case).
