replace powered by ESRI
16426
70
07-22-2010 02:01 AM
NatashaManzuiga
Hi all I perfectly replaced ESRI logo with this script:
http://forums.esri.com/thread.asp?t=287497&f=2421&c=158#912795
Now how can I replace link to esri.com/flex?
Naty
deleted-user-rQoEFM5qzbHE
I tried the code mentioned above along with the Embed line mentioned in the link. Unfortunately, I get an error in the Embed line. It states that 'Access of undefined property source. Any thoughts? Thanks.
RobertScheitlin__GISP
Jeremy,
   Did you change the source to an image that you have in your file structure?
example is if you are using the FleViewer2.0 there is no such directory as com/esri/solutions/flexviewer/assets/images it would be assets/images instead.
[Embed(source="com/esri/solutions/flexviewer/assets/images/powered_by_ME.png")]
   private var myLogo:Class;
Yeah, I changed it to the assets/images structure found in Version 2.0. These are the two lines:
[Embed(source="assets/images/NEW_ITRE_LOGO1.png")]
Jeremy,
   OK, do you have the
near the top of the MapManager.mxml where the Private Var's are located or did you just paste that inside a function (which you can not do)?
I placed the two lines immediately below the last 'private var ...' line.
An update to my problem. When I refresh the map service, I am getting an ActionScript error. The first line in the error points to the following line of code in the MapManager.mxml
if(component.className == "StaticLayer")
I still have not resolved the error the comes up when compiling on the "Embed" line. Any thoughts?
Thanks.
Jeremy,
  You need these 2 imports
import mx.core.UIComponent;
   import mx.controls.Image;
Unfortunately, I already had those two import statements in the code. So, it must be something else.
Jeremy,
   Post your whole MapManager.mxml there is a simple explanation to this; somewhere...
Since I am new to this, it would be very easy for me to something obvious. Apparently the code is too long to enter into this comment section. I have attached it instead.
Thanks.
