renderer function for graphic layer
798
09-28-2010 01:01 PM
abukhan
Can renderer be a function in graphicLayer something like
<esri:GraphicsLayer  id="graphicsLayerLoanHMDA" renderer="{getloanhmdarenderer();}" />
private function getloanhmdarenderer():Renderer
                                        var simplerenderer:SimpleRenderer = new SimpleRenderer();
    return simplerenderer as renderer;
It does not work...
DasaPaddock
Is the problem when the function is being called? It should work as you've written it, but the function will only be called once unless the function takes a bindable argument, in which case it'd be called whenever the binding on the argument is triggered.
