Remove Null Values from Query Widget Dropdown
994
04-20-2011 09:53 AM
DaveKirkley
I have a layer of Streets that has a number of Null Values in the Street Name field. I also have the list sorted ascending AC that shows all the blank Street Names First.  Where in the code can you remove these values from the list?
by Anonymous User
Not applicable
You can apply a filter function the the ArrayCollection to do that. There are tons of examples describing how to do that if the search the internet (e.g. flex arraycollection filterfunction).
DaveKirkley
Here is the latest version of my code. No Errors, but it still produces Empty Fields
//create queryrresults
            private function createQueryResults(featureSet:FeatureSet):ArrayCollection
                graphicsLayer.clear();
                var result:ArrayCollection = new ArrayCollection;
    result.filterFunction = function(queryResult:*):Boolean{
     return (StringUtil.trim(queryResult.name)!=""); //
    result.refresh();
                if (!queryTitleField)
                    queryTitleField = featureSet.displayFieldName;
                for each (var graphic:Graphic in featureSet.features)
                    var value:String = "";
                    var title:String = "";
                    var content:String = "";
                    var link:String = "";
                    if (allFields)
                        if (featureSet.fields) // requires ArcGIS Server 10.0+
                            for each (var field:Field in featureSet.fields)
                                if (field.name in graphic.attributes)
                                    displayFields(field.name, getFieldXML(field.name), field);
                        else
                            for (var fieldName:String in graphic.attributes)
                                displayFields(fieldName, getFieldXML(fieldName), null);
                    else
                        for each (var fieldXML:XML in fields) // display the fields in the same order as specified
                            if (fieldXML.@name[0] in graphic.attributes)
                                displayFields(fieldXML.@name[0], fieldXML, getField(fieldXML.@name[0], featureSet));
                    function displayFields(fieldName:String, fieldXML:XML, field:Field):void
                        value = graphic.attributes[fieldName] ? String(graphic.attributes[fieldName]) : "";
                        if (value)
                            var isDateField:Boolean;
                            var dateFormat:String;
                            if (fieldXML)
                                dateFormat = fieldXML.@dateformat[0];
                                if (dateFormat)
                                    isDateField = true;
                            if (!isDateField && field)
                                isDateField = field.type == Field.TYPE_DATE;
                            if (isDateField)
                                var dateMS:Number = Number(value);
                                if (!isNaN(dateMS))
                                    value = msToDate(dateMS, dateFormat);
                        if (fieldName.toUpperCase() == queryTitleField.toUpperCase())
                            title = value;
                            if (!title)
                                title = widgetTitle;
                        else if (fieldName.toUpperCase() == queryLinkField.toUpperCase())
                            link = value;
                        else if (fieldName.toUpperCase() != "SHAPE_LENGTH" && fieldName.toUpperCase() != "SHAPE_AREA")
                            if (fieldXML && fieldXML.@alias[0])
                                content += fieldXML.@alias[0];
                            else
                                content += featureSet.fieldAliases[fieldName];
                            content += ": " + value + "\n";
                    graphic.addEventListener(MouseEvent.CLICK, mouseClickGraphic);
                    var queryResult:QueryResult = new QueryResult();
                    queryResult.title = title;
                    queryResult.content = content;
                    queryResult.point = getGeomCenter(graphic);
     queryResult.link = link ? link : null;
                    queryResult.geometry = graphic.geometry;
                    switch (graphic.geometry.type)
                        case Geometry.POLYLINE:
                            graphic.symbol = queryResult.symbol = resultLineSymbol;
                            break;
                        case Geometry.POLYGON:
                            graphic.symbol = queryResult.symbol = resultFillSymbol;
                            break;
                        case Geometry.MAPPOINT:
                            graphic.symbol = queryResult.symbol = resultMarkerSymbol;
                            break;
                    graphic.attributes = queryResult;
                    if (queryResult.point && !isNaN(queryResult.point.x) && !isNaN(queryResult.point.y)) // make sure it is a valid point
                        result.addItem(queryResult);
                        graphicsLayer.add(graphic);
                return result;
            private function getFieldXML(fieldName:String):XML
                var result:XML;
                    if (fieldName == fieldXML.@name[0])
                        result = fieldXML;
                        break;
                return result;
            private function getField(fieldName:String, featureSet:FeatureSet):Field
                var result:Field;
                    if (fieldName == field.name)
                        result = field;
                        break;
                return result;
   // sort field function- added by Dkirkley April 13, 2011
   private function SortDataGridData(strFieldNameToSort:String,recACToSort:ArrayCollection):ArrayCollection{
    try{
     // CC -Orginal code by BJ and found at forum post http://forums.esri.com/Thread.asp?c=158&f=2421&t=285419&mc=6#msgid886159
     var dataSortField:SortField = new SortField();
     dataSortField.name=strFieldNameToSort;
     var alphabetDataSort:Sort = new Sort();
     alphabetDataSort.fields=[dataSortField];
     recACToSort.sort=alphabetDataSort;
     recACToSort.refresh();
    catch(error:Error){
    return recACToSort;
