Relationship Inspector - editEnabled
1088
12-09-2013 12:20 PM
ionarade_lima
I changed the relationship inspector example to include the editEnabled property set to true so I can edit the records. However I don't see a way to edit any of the records. Why isn't allowing me to edit? Thank you!
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:mx="library://ns.adobe.com/flex/mx"
               xmlns:esri="http://www.esri.com/2008/ags"
               pageTitle="Using RelationshipInspector (view)">
    Description:
    This sample demonstrates how to use the FeatureLayer to perform graphical selections,
    and then use that selection to view related records using the RelationshipInspector
    component.
    The first selection which is made by a single click on the map selects
    features in the FeatureLayer.  The selected graphic is then assigned to the RelationshipInspector
    and the RelationshipInspector is assigned to the map's infoWindow content property.  The
    graphic's location is then used to display the map's InfoWindow.
    The RelationshipInspector is doing all the work here, if you want more control you can
    modify the default skin or check out the "Related Records" sample found under the "FeatureLayer"
    folder in the samples.
    This sample will look for related records in the TOPS table.
    In this case, the relations have been setup in ArcMap, and the relationships information
    made available in the Service Directory which lists two relationships.
    See http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer
    * a table - Tops: http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/2
    * a point layer - Wells : http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/0
    Documentation:
    For more information, see the API documentation.
    http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/components/RelationshipInspector.html
    http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/events/FeatureLayerEvent.html
    http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/events/MapMouseEvent.html
    http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/geometry/Extent.html
    http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/geometry/MapPoint.html
    http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/layers/FeatureLayer.html#mode
    http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/layers/FeatureLayer.html#selectFeatures()
    http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/tasks/supportClasses/Query.html
    ArcGIS REST API documentation
    http://resources.arcgis.com/en/help/rest/apiref/queryrelatedrecords.html
    ArcGIS for Desktop documentation
    About relating tables
    http://resources.arcgis.com/en/help/main/10.1/index.html#/About_joining_and_relating_tables/005s0000002n000000/
    Essentials of relating tables
    http://resources.arcgis.com/en/help/main/10.1/index.html#/Essentials_of_relating_tables/005s0000002t000000/
    Relating the attributes in one table to another
    http://resources.arcgis.com/en/help/main/10.1/index.html#/Relating_the_attributes_in_one_table_to_another/005s0000002v000000/
    <fx:Script>
        <![CDATA[
            import com.esri.ags.events.FeatureLayerEvent;
            import com.esri.ags.events.MapMouseEvent;
            import com.esri.ags.geometry.Extent;
            import com.esri.ags.geometry.MapPoint;
            import com.esri.ags.tasks.supportClasses.Query;
            import mx.controls.Alert;
            private function findWells(event:MapMouseEvent):void
                // find wells near the mouse click
                var tol:Number = map.extent.width / map.width * 5;
                var x:Number = event.mapPoint.x;
                var y:Number = event.mapPoint.y;
                var queryExtent:Extent = new Extent(x - tol, y - tol, x + tol, y + tol, event.mapPoint.spatialReference);
                var thisSelectionQuery:Query = new Query();
                thisSelectionQuery.geometry = queryExtent;
                wellsLayer.selectFeatures(thisSelectionQuery, FeatureLayer.SELECTION_NEW);
            private function wellsLayer_selectionCompleteHandler(event:FeatureLayerEvent):void
                // check the first return feature to see if it has any related features
                if (event.features.length > 0)
                    map.infoWindow.content = relationshipInspector;
                    relationshipInspector.infoWindowLabel = "ID: " + event.features[0].attributes["KID"];
                    relationshipInspector.graphic = event.features[0];
                    map.infoWindow.show(event.features[0].geometry as MapPoint);
                else
                    map.infoWindow.hide();
                    Alert.show("No wells found here, please try somewhere else.", "No features");
    </fx:Script>
    <fx:Declarations>
        <esri:RelationshipInspector id="relationshipInspector"
                                    width="300" height="300"
         editEnabled="true"
    </fx:Declarations>
    <s:controlBarContent>
        <s:RichText width="100%">
            component.  Click a well location to select and view its related record information.
        </s:RichText>
    </s:controlBarContent>
    <esri:Map id="map" mapClick="findWells(event)">
        <esri:extent>
            <esri:Extent xmin="-10844058" ymin="4513057" xmax="-10837656" ymax="4516411">
                <esri:SpatialReference wkid="102100"/>
            </esri:Extent>
        </esri:extent>
        <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/>
        <esri:ArcGISDynamicMapServiceLayer alpha="0.7" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer">
            <esri:visibleLayers>
                <s:ArrayCollection>
                    <fx:Number>0</fx:Number>
                    <fx:Number>1</fx:Number>
                </s:ArrayCollection>
            </esri:visibleLayers>
        </esri:ArcGISDynamicMapServiceLayer>
        <esri:FeatureLayer id="wellsLayer"
                           mode="selection"
                           outFields="[KID]"
                           selectionComplete="wellsLayer_selectionCompleteHandler(event)"
                           url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/0"/>
    </esri:Map>
</s:Application>
BenjaminMercier
Actually it's totally logical that you can't edit because the layer you are using is a MapService (so not editable by definition). Please use a feature layer instead of this one.
You should change the URL of the layer defined between <esri:FeatureLayer>
     mode="selection"
     outFields="[KID]"
     url="http://yourServer/ArcGIS/rest/services/yourFolder/FeatureServer/0"/>
PS: Please could you avoid to open 2 discussions for the same subject for the well use of this forum.
ionarawilson1
Hi Benjamin,
Thank you for your help, but that does not solve the problem for this particular example. But I figured out how to use the relationship inspector. I will be careful with not posting multiple threads. However the questions were about different samples and I think people usually answer when there are not too many questions in one post. Thanks
