reference "widgets" class from com.customdirectory
1378
06-02-2011 08:36 AM
AshleyOwens
Is it possible to reference an ActionScript file in a widgets subdirectory from com.customdirectory? For example, I would like to reference widgets.QueryBuilderWidget.SearchResult.as from a custom class com.gtc.export.ExportToXL. The "com" package is on the same level as the "esri" package.
Thanks!
RobertScheitlin__GISP
sure you can!
AshleyOwens
Great! Can you please provide an example?
Ashley,
   An example is not really necessary here. All you do is import the widgets.QueryBuilderWidget.SearchResult in your ExportToXL code...
AshleyOwens
Worked perfectly.  Once again, THANK YOU!!
