RE:  Weather Underground Widget Error
1027
08-22-2011 08:36 PM
DonaldCatanzaro
Hi All,
I tried to put the Weather Underground widget in my SFV and I am getting the following error:
Description Resource Path Location Type
1061: Call to a possibly undefined method addListener through a reference with static type Class. WUndergroundWidget.mxml /NGFlexViewer/src/widgets/WeatherUnderground line 235 Flex Problem
Line 235 in the widget states:  AppEvent.addListener(AppEvent.DATA_PUBLISH, sharedDataUpdated);
The error prevents the widget from functioning.  All I did was download the zip file, unzip it, put the uncompiled folder in my src, update the Flex Modules, add the text to the config.xml.  Any ideas ?
Thanks in advance
DonaldCatanzaro
Hi All,
Upon further review it also appears that there is no SWF file in the directory C:\Inetpub\wwwroot\flexviewerdebug\widgets\WeatherUnderground so it appears to not compiling ?
-Don
RobertScheitlin__GISP
Don,
  Flex Viewer/Widget questions belong in the Flex Viewer forum:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
It sounds like you missed this part of the readme.txt.
For the Uncompiled you need to copy the WeatherUnderground folder to src/widgets then
add WUndergroundWidget.mxml to your flex projects modules list
, and compile your
project as well as add the widget line above to your config.xml.
DonaldCatanzaro
