Question about Edit Widget 2.0 using a file geodatabase
1018
09-15-2010 08:18 AM
JoshCalhoun
Does the Edit Widget work with a file geodatabase? Does it have to be in SDE?
thanks
Josh
BjornSvensson
Esri Alum
"The features must come from an ArcSDE geodatabase. This geodatabase can be licensed for either workgroup or enterprise use and does not have to be versioned."
http://help.arcgis.com/en/webapi/flex/help/index.html#editing.htm
JoshCalhoun
One more question Bjorn. Please excuse my ignorance, as all this is new to me and I am trying to sort out what needs to happen in my organization.
How do I handle permissions to the SDE db? We have our SDE set up with db authentication. Do I need to create a login page for the user. Only one user is going to edit the data set. Is this edit widget from the 2.0 sample map viewer only set up for anonymous users/editors?
Thanks Bjorn for replying to my message. Any help you can give me will be greatly appreciated.
Josh Calhoun
City of Chattanooga TN
