QueryTask and Joins
781
05-03-2010 02:28 PM
JamesKo
I've created a mapservice comprised of a feature class with a joined Oracle table. The identifyTask and the findTask both work when I query the rest service. However, when I try to perform a queryTask, I get the following error message: Unable to perform query. Please check your parameters.
Anyone else have this problem? Is this a bug?
Thanks in advance...
JustinWilliams
Hey there,
If you haven't already found a solution to this...
I ran into the same problem myself and it looks like if you are using a joined table which uses a configuration keyword you need to give the fully qualified name to the field you want to query.
It would look something like this..
Keyword.Source.Field
I hope that helps!
