Query Widget from New Sample Viewer
1804
04-07-2010 09:35 AM
JamesFaron
I need to modify this widget to return only two 'baseMaps' (it is written to return all baseMaps). I have been successfull except for one problem: the list in the combo box populates with duplicate values, 5 in fact, or 10 if I choose to include 2 layers, as in my example below. I use an index value to select the layer (the default is var i from the loop).
The original script is as follows:
private function getBasemapLayer():ArrayCollection
    var baseMaps:ArrayCollection = new ArrayCollection();
    for(var i:Number=0; i<configData.configBasemaps.length; i++)
           baseMaps.addItem(configData.configBasemaps.label);
    return baseMaps;
  // TODO: Change to pull from configdata object
      private function getLayers():ArrayCollection
    var basemapLyrs:ArrayCollection = getBasemapLayer();
    var layers:ArrayCollection = new ArrayCollection();
    for(var i:Number = map.layerIds.length -1; i >= 0; i--)
     var basemapLyr:Boolean = false;
     for each(var id:String in basemapLyrs){
      if (map.layerIds == id){
       basemapLyr = true;
       break;
     if (basemapLyr) continue;
     var layer:Layer = map.getLayer(map.layerIds);
     if(!(layer is GraphicsLayer))
      layers.addItem(layer);
    return layers;
My modification is to the last section:
     var layer:Layer = map.getLayer(map.layerIds[2]);
     var layer2:Layer = map.getLayer(map.layerIds[3]);
      layers.addItem(layer2);
    return layers;
Attached is a jpg of the combo box: it is populated with the two layers, but in pairs of 5, i.e. five duplicate items each (the second layer is in white, hard to see) .
The dataprovider for the combo box is mMapServices, which is declared = to the getLayers() function in the init().
Jim Faron
RobertScheitlin__GISP
Jim,
   Use this instead
  if(layer.id == "the name of your first layer" || layer.id == "the name of your second layer")
 return layers;
JamesFaron
Robert,
Worked perfectly!
Thanks once again for your help.
Jim Faron
JasonHancheruk
I have a newbie question regarding the Query Builder Widget. If i am okay taking all the layers under a service, how do I go about setting that up. Right now I have numerous layers under two different livemaps, but when I click on the Map Service tab, I receive the two services but "no layers" found after clicking "apply" and then "search".
Any help would be great.
Jason
SusanMordy1
I was able to implement Robert's above code to define which map services are available in the drop down box.
Does anyone know how I can define which map service layers are available in the 'Target Layer' drop down box?
Thanks very much.
CristianJonhson
What about if i want to ask for unique values of a field? cause it will make a query @ all my layers but will return me only 500(or configured number of) features, how i can set the query to select only "DISTINCT" values?
Thanks in advance,
Cristiano Benato.
