query integer
2489
9
03-22-2011 01:37 PM
JonPedder
Hi, I'm looking to query a field in a published featureservice of type integer. I have a text box above the data grid for the user to input a value and have the grid display the results. So far so good, this code does work.
<s:TextInput id="textPeriod" enabled="true"/>
<s:Button id="textButton" label="Go" enabled="true" click="doAssignments()"/>
id="queryAssignments"
   returnGeometry="true"
   outFields="[assignment_number,team_name,timeslider,team_name,description]"
   where="period={textPeriod.text}"
I'd like that if the textPeriod entry is empty, all records are returned, I just don't seem to be able to get this to work.
I've been trying several methods but without any success, such as
where="1=1 AND period={textPeriod.text}"
wild cards don't appear to work on Integers as I've tried passing % and *
Any advice would be greatly appreciated
Jon
JohnGarvey
This is general, but it seems you will need a conditional statement to determine the value of the input box.
if(inputBox.value){
' insert where statement
else{
query.where= "x is not null".
JonPedder
Thanks, i actually did try this but failed to pass the correct parameters along to the query. I've tried the following but get syntax errors. I don't think I can use {textPeriod.text} to pull the data from the input field.
protected function textButton_clickHandler(event:MouseEvent):void
    var resultPeriod:String = public
    if ({textPeriod.text} > 0) {
     resultPeriod = {textPeriod.text}
     else if {
     resultPeriod = "1=1"
JonPedder
next effort but still a no go.
protected function textButton_clickHandler(event:MouseEvent,inputPeriod):void
    if (inputPeriod > "") {
     resultPeriod = inputPeriod
     else if (inputPeriod= null) {
  <s:Button id="textButton" label="Go" enabled="true" click="textButton_clickHandler(event)"/>
<esri:Query
   where="period=resultPeriod"
getting frustrated, going home 😉
Thanks
JohnGarvey
I think i am confused. Are you doing this in MXML or actionscript. In actionscript, you do not need the curly braces to refer to the variables.
If as3:
In the conditional part, you could test whether there is textInput.text or whether textInput.text.length>0.
if(textInput.text) or (textInput.text.length>0)
The all-inclusive where clause for the query should still be 'period is not null'
JonPedder
Thanks very much John, you can probably tell I'm a newbie and had no idea you didn't need {} within actionscript. I'm pretty close I think but the query itself isn't executing. here's what I have.
Here�??s the defined query
<esri:QueryTask
                  id="queryTaskAssignments"
                  url="http://blah blah/MapServer/6"
            <esri:Query
                  where="resultPeriod"
Here�??s the button and text box
Here�??s the actionscript
            // function to return assignments to data grid
                  public function textButton_clickHandler(event:MouseEvent):void
                        var resultPeriod:String = "";
                        if (textPeriod.text>"") {
                              resultPeriod = new String('period ='.concat(textPeriod.text))
                        if (textPeriod.text=="") {
                        queryTaskAssignments.execute(queryAssignments);
I tested with Alert.Show(resultperiod) and get the correct strings to pass to the where= statement, no compiler errors but it�??s not firing the query. Is there something I need to do to pass values from with an actionscrip to mxml?
Thanks again
Jon
JohnGarvey
I think we are close.
You will first need to declare the resultPeriod variable outside the function:
private var resultPeriod:string;
                              resultPeriod = "period="+ textPeriod.text;
                        if (textPeriod.text==null) {
                              resultPeriod = "period is not null"
For the query, make the queryAssignment.where=resultPeriod (no quotes).
You also need to assign a handler to the queryTask. You can do this in the MXML by declaring a function in the result property, actionscript by adding an eventlistener, or by binding the executedLastResult of the query task to a component.
hope this helps.
JonPedder
Thanks again John. I had just found out about declaring the var outside the function so i did move it.
i see the changes in the function code and 'get' those, not quite sure what you mean about queryAssignment.where=resultPeriod
if I change the query to exactly this I get an error that quotes are expected, if I add quotes I get an error that 'State' where was referenced without being declared.
Again thanks for helping
JonPedder
I'm also hopelessly lost on your explanation here. Sorry
"You also need to assign a handler to the queryTask. You can do this in the MXML by declaring a function in the result property, actionscript by adding an eventlistener, or by binding the executedLastResult of the query task to a component."
JohnGarvey
Sorry, try this.
Your query is in MXML so you do need the curly brackets to use variables (in the where=):
<esri:Query
                  where="{resultPeriod}"
As for a query Handler. The server sends back information so you need a function that catches the info and does something with it.
Execute the queryTask like this (make sure to import the responder and featureSet):
queryTaskAssignments.execute(queryAssignments, new AsyncResponder( onResult, onFault ));
                function onResult( featureSet : FeatureSet, token : Object = null ) : void
                  Alert.show(featureSet.displayFieldName);
                function onFault( info : Object, token : Object = null ) : void
                    Alert.show( info.toString() );
Put a break point in the onResult function and run in debug mode. This will let you explore what the server returns.
Hope this is a little clearer.
