Query feature joined with table
1001
04-26-2011 11:58 AM
TarlNeitzey
This seems like it should work pretty easily but I keep getting the following error:
[RPC Fault faultString="Unable to complete  operation." faultCode="400" faultDetail="Unable to complete Query operation."]
Here is the relevant code:
<esri:QueryTask id="queryTask"
   showBusyCursor="true"
   url="http://ws-63-neptune/ArcGIS/rest/services/PipelineWorkStatus/MapServer/1"
   useAMF="false"/>
<esri:Query id="query"
   outSpatialReference="{myMapStyle.spatialReference}"
   returnGeometry="true"
   text="527289">
<esri:outFields>
   <fx:String>COMPKEY</fx:String>
   </esri:outFields>
</esri:Query>
<esri:Map id="myMapStyle">
   <esri:ArcGISTiledMapServiceLayer
      url="http://ws-63-neptune/ArcGIS/rest/services/OrthosCached/MapServer"/>
   <esri:ArcGISDynamicMapServiceLayer id="legendLayer" name="Work"
      url="http://ws-63-neptune/ArcGIS/rest/services/PipelineWorkStatus/MapServer"/>
   <esri:GraphicsLayer id="myGraphicsLayer"
      graphicProvider="{queryTask.executeLastResult.features}" />
</esri:Map>
I can run the same query through the services pages on the server so the issue must be how I'm attempting to do this through code.
BorjaParés
Hi!
I'm having the same problem.
I'm executen a QueryTask to a layer id via rest. The layer in the mxd has a join with a table. I get the: unable to complete operation error.
Any suggestios or ideas?
Thanks in advance!
RobertScheitlin__GISP
If you are preforming a query on a joined layer than you need to ensure you are using the full joined field name like table1.field1. Also ensure that you do not have the Shape and/or Objectid fields hidden in the mxd/msd that the mapservice comes from.
