Publishing map service for Flex using JSF-Java
628
04-28-2010 11:38 PM
VikramTripathi
Dear all
we have deployed map service in arcGIS(JSF java) which running perfectly, but if i want to use same web service from Flex (using Java) it does not working, not showing map from http://localhost:8080/GeoFx/map.html, but when i try to run from flash plater 10 it again runs (file: D:/flex_workspace/flexmap/bin-debug/map.swf).
can u tell what problem may be? or what should  i have to change service???
