PROBLEMS WITH ROUTE WIDGET VERSION 2.3.1
706
05-18-2011 12:35 PM
EmilioSolano
Has someone else had problems with this widget and found the fix? I have problems trying to get it working all the way. So far only works by selecting the addresses by pointing in the map, but not when typing the addresses and hitting the Enter key.
The prior version worked very well. I will appreciate any help or suggestions. I obtained the same results using the compiled version and using the source code and compiling it my self. I am not a programmer which prevent me from analyzing the source code.
This is an outstanding widget by R. Scheitlin and very useful too.
RobertScheitlin__GISP
Emilio,
   This issue has been fixed in version 2.3.2.
