Problem with query expression when using a File geodatabase
2267
9
01-18-2013 07:37 AM
ionarawilson1
I have a web map app with a search tool with one text input for company's name, one dropdown menu for county and two drop down menus for industry and industry type. I previously had my geodatabase in a SDE environment but after upgrading to ArcGIS Server 10.1, I decided to use a file geodatabase because it is easier. However my query expressionf for the company is not working properly anymore.
Here is the code snippet:
 var expr:String = "";   if (qText.text != "") {  // for the text with apostrophe be recognized on the query qText.text = qText.text.replace("'","''") expr = "Company Like '%" + qText.text + "%' AND Status_not = ' '" ;   }
So, do you guys have any idea in how to make this work again with a file geodatabase?
If I search for "tem", it does not bring me the companies that start with "Tem" anymore, just the ones that have tem somewhere in their name. If I search for Caesar's or Cae, it does not bring me the company with that name, but if I search for aes, it will bring that company and others that have aes somewhere in their name. Thank you for any help!!!
RobertScheitlin__GISP
Ionara,
   Simply use this:
expr = "Upper(Company) Like Upper('%" + qText.text + "%') AND Status_not = ''" ;
AnthonyGiles
Honored Contributor
Ionara,
I think the wildcard for file geodatabases is * not %, have you tried that,
Regards
Anthony
Anthony,
   No the * is for Personal Geodatabases not File GDB. I am not sure what Ionara's issue is.
ionarawilson1
I found out the problem but still don't have a solution. It is because of case sensitivity. In my database I have names partly in Upper case like "AES Custom Woods" or "AGE Industries, Inc", and "NAPCO" (all in upper case" and also like this "Temple-Inland Forestry Company". How can I change the query to accomodate all the options? Thank you for any help!
Ionara,
   Simply use this:
T__WayneWhitley
Honored Contributor
...a bit of a workaround, but for now you could replace your current exp with:
expr = "Company Like '%" + qText.text + "%' AND Status_not = ' ' OR Company Like '" + qText.text + "%' AND Status_not = ' ' OR Company Like '%" + qText.text + "' AND Status_not = ' '"
It's ugly, but will work I think.
EDIT:
Please disregard, didn't know it was due to case.
ionarawilson1
Robert, you are, as always, my hero!!! Thanks again!!! It works!!!
Thank you Wayne for trying but it does not solve the problem of the case sensitivity, thank you!
ionarawilson1
Robert,
By the way, why do we need the upper function in front of company?
Ionara,
  You have to tell the SQL to capitalize the company field data and the users input to resolve the case sensitivity.
ionarawilson1
thank you Robert!
