Problem with Export Map to PDF code
904
01-21-2011 07:38 AM
francescodi_vito
Hi guys,
i have write a script for export Map of my web personal application. The code is
<mx:Script>
  <![CDATA[
   public function PrintPDFx():void
    var sURL:String;
    sURL = "http://193.204.163.134/ArcGIS/rest/services/Roma/Carg_Roma/MapServer/export";
    sURL = "?bbox="+myMap.extent.xmin+","+myMap.extent.ymin+","+myMap.extent.xmax+","+myMap.extent.ymax;
    //sURL+="&layers=";
    sURL+="&size="+myMap.width+","+myMap.height;
    sURL+="&format=pdf";
    sURL+="&trasparent=false";
    //sURL+="&dpi";
    sURL+="&f=image";
    sURL+="&width"+myMap.width;
    sURL+="&height"+myMap.height;
    navigateToURL(new URLRequest(sURL),'_blank');
but i have a problem. When i click the button on my web application, opens a new website but not pdf with the service I set it to print.
Why? My script is wrong?
Drew
You have a small error  when building your string.
add a + sign in your second line..
It should look like so.
[code
sURL += "?bbox="+myMap.extent.xmin+","+myMap.extent.ymin+" ,"+myMap.extent.xmax+","+myMap.extent.ymax;
Drew
francescodi_vito
[code
Drew
Thanks you are right
