GeometryService.Relation NON-IDENTICAL?
1085
11-05-2010 12:03 PM
TylerWaring
Greetings Everyone,
I have been struggling to figure out how to perform a spatial test on a graphics layer and a featureset.
What I am trying to do is extend the graphical search functionality in the search widget so that a user can press the ???A??? key and add additional features to both the graphics layer and the RecordData class object.
I have figured the main functions for this extension but now I am finding that if the added features overlap the existing graphics layer then duplicates will be produced in both the graphics layer and the RecordData class object.
To overcome this problem, I would like to use compare the existing in map graphicslayer to the new featureset that is produced when an additional graphical query is made. I think I am looking to use a GeometryService.relation method with the spatialRelationship parameter set to SPATIAL_REL_RELATION. However I have no Idea how to set up the comparisonString.
I???ve tried to jump into the Shape Comparison Language documentation but I must admit that it is completely over my head. I have tried my best to generate the correct parameters but I am obviously doing something wrong. Here is what I???ve got:
myGeometryService.relation(compareArray1, compareArray2,GeometryService.SPATIAL_REL_RELATION,"compareArray1 != compareArray2")
The Error I get whilst running this method is:
[FaultEvent fault=[RPC Fault faultString="Object reference not set to an instance of an object." faultCode="500" faultDetail="Unable to perform the relation operation"] messageId=null type="fault" bubbles=false cancelable=true eventPhase=2]
Does anyone know what I may be doing wrong?
Tyler Waring
DasaPaddock
Another option could be to try and prevent the duplicates by not letting the server return the features that have already been loaded. Try adding a NOT IN SQL clause to the Query.where property.
e.g. OBJECTID NOT IN (1, 2, 3, ...)
TylerWaring
Thanks, That's exactly what I needed. Thanks for finding the right size solution for my problem.
I am curious though, how do you integrate the Shape Comparison Language with a Flex applicaiton using GeometryService.SPATIAL_REL_RELATION? It sounds both interesting and powerful.
Any information will be greatly appreciated.
Tyler
nicogis
in relation you can write
myGeometryService.relation(compareArray1, compareArray2,GeometryService.SPATIAL_REL_RELATION ,"G1 != G2")
you must use G1 (compareArray1) and G2(compareArray2)  and not compareArray1 and not compareArray2
confront is done for index:
compareArray1[0]  with compareArray2[0]
compareArray1[1]  with compareArray2[1]
IDENTICAL (G1, G2) = TRUE
IDENTICAL (G1, G2) = FALSE
G1 == G2
G1 = G2
G1 != G2
you also can reverse order
G2 != G2
