Problem with date Query
1057
04-05-2012 09:18 AM
Yusufalbanki
Hi All,
I have a query that should return records according to selected duration. I did it but it return strange records.
my function :
protected function button1_clickHandler(event:MouseEvent):void
    datetimeFormatter.dateTimePattern="yyyy-MM-dd HH:mm:ss";
    var strFromDate:String=datetimeFormatter.format(dfFrom.selectedDate);
    var strToDate:String=datetimeFormatter.format(dfTo.selectedDate);
    getIncidentsParam.where="Inc_AlarmTime  > date '"+strFromDate+"' AND Inc_AlarmTime  < date '"+strToDate+"'";
    getIncidents.execute(getIncidentsParam);
I read the date from datefield.
The returned records sometimes before the duration like attached snapshot[ATTACH=CONFIG]13276[/ATTACH]
Is there solution for this problem.
Thanks
Yusuf
RobertScheitlin__GISP
Yusuf,
   I spent a good deal of time with esri tech support on date range search issue and basically this is what I got to work:
FeatLay.timeDefinition = new TimeExtent(DatePicker1.selectedDate,DatePicker2.selectedDate);
Apply a time extent to a actual featurelayer.
We never got a great than or equal to and a less than or equal to query to work in a where clause.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote) as shown below:
Yusufalbanki
Thank you very much Robert for your reply.
DasaPaddock
