Problem on passing the input file to Geoprocessing service
5921
6
10-14-2012 11:15 PM
sobarim-amin
All,
Kindly advice on my problem.
I created a geoprocessing tool and published it to ArcGIS server.
But since the input for the tool is a datafile, it always failed to get the input.
I am using filereference class to upload the file, but when it passed the datafile.url doesn't seems to be succesfull.
See below code I use to upload the file.
               request = new URLRequest("http://myserver/arcgisoutput/TestNewLine2.txt")
try
  fileRef.upload(request);
                 catch (error:Error)
  trace("Unable to upload file.");
regards,
Sobari
IvanBespalov
sobarim-amin
http://forums.arcgis.com/threads/64114-Uploads-capability-on-Geoprocessor?highlight=upload
Thanks Ivan,
But how can I pass the uploaded file as GP parameter which has input type as GPDataFile  ?
This is what I tested, but does not work
private function onUploadCompleteData(event:DataEvent):void
   try
gp.execute(event.data);
catch (error:Error)
Alert.show("gpExecute error \n" + error.message );
Please advice
Regards,
Sobari
IvanBespalov
From ESRI help (find GPDataFile😞
import com.esri.ags.events.GeoprocessorEvent;
import com.esri.ags.tasks.Geoprocessor;
import com.esri.ags.tasks.supportClasses.DataFile;
import com.esri.ags.tasks.supportClasses.JobInfo;
import com.esri.ags.utils.JSONUtil;
import mx.rpc.AsyncResponder;
import mx.rpc.Fault;
private function submitJob():void
 var gpUrl:String = "http://server/arcgis/rest/services/folder/service/GPServer";
 var gp:Geoprocessor = new Geoprocessor(gpUrl);
 var dataFile:DataFile = new DataFile("http://server/folder/file.txt");
 var gpParams:Object = new Object();
        gpParams["Input_Data_File_Parameter_Name"] = JSONUtil.encode(dataFile);
 /* wrong
         gpParams["Input_Data_File_Parameter_Name"] = dataFile.toJSON();
 // add other req. parameters
 // if service is Asynchronous
 gp.submitJob(gpParams, new AsyncResponder(onJobComplete, onJobFault));
 // else
 gp.addEventListener(GeoprocessorEvent.EXECUTE_COMPLETE, onExecuteComplete);
 gp.execute(gpParams);
 * Listen job complete server response
protected function onJobComplete(result:JobInfo, token:Object = null):void
 if (result.jobStatus == JobInfo.STATUS_SUCCEEDED)
  //TODO: complete code
 else
 * Listen server error responses
protected function onJobFault(fault:Fault, token:Object = null):void
 trace(fault.message.toString());
protected function onExecuteComplete(event:GeoprocessorEvent):void
sobarim-amin
Hi ibespalov ,
Thanks for your great help..
things is now progressing
But I still have problem:
on dataFile.toJSON, toJSON is not being recognised so I omit toJSON.
when it submit the job,after it process for a few seconds  i received esriJobFailed message (onJobComplete)
Appreciate your advice
Regards,
Sobari
IvanBespalov
I was wrong. Haste. 🙂
But you could also read the help. :cool:
try it:
gpParams["Input_Data_File_Parameter_Name"] = com.esri.ags.utils.JSONUtil.encode(dataFile);
IMHO, the best practice is testing your service in browser (REST API) at first. Most of browsers comes with "network monitoring tools" (usually F12 key pressing).
Open your GP service, set input parameters - find request in monitoring console ... If your service works - start playing with web APIs.
Good luck.
sobarim-amin
ibespalov,
As you suggested, I tested the service in browser (REST API), and this was the error I got.
Job ID: jbd6e30cce4654fa48c9272092d21573d
Job Status: esriJobFailed
Job Messages:
esriJobMessageTypeInformative: Submitted.
esriJobMessageTypeInformative: Executing...
esriJobMessageTypeError: ERROR 000840: The value is not a Text File.
esriJobMessageTypeError: Failed.
I was uploading a text file but why the error says "The value is not a Text File. "
Does the text file changed to ZIP file when it uploaded to server using fileReference in flex?
