problem about ArcGIS API for Flex3.0
1454
08-07-2012 02:15 AM
galechaung
I tried to use the samples of ArcGIS offical website in my flash builder4.5,but the map does not show up.
The source code is below. Help me!!!!
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:esri="http://www.esri.com/2008/ags"
pageTitle="World Topographic Map">
This sample shows how to add a topographic basemap layer to your application.
The sample uses a cached map service from ArcGIS Online.
You can browse the ArcGIS.com site for additional online basemap and reference
map services or publish your own geographic data as a service using ArcGIS Server.
<fx:Declarations>
<esri:Extent id="initialExtent"
xmin="-13635000" ymin="4541000" xmax="-13625000" ymax="4547000">
<esri:SpatialReference wkid="102100"/>
</esri:Extent>
</fx:Declarations>
<esri:Map extent="{initialExtent}">
<esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
</esri:Map>
</s:Application>
KenBuja
MVP Esteemed Contributor
Also, the Flex 3.0 API requires the Adobe Flex 4.6 SDK or higher, which in turn requires at least Flash Player 11.1.
IvanBespalov
are you sure that you have fulfilled all the tips listed here?
Some useful links:
Build Your First Flex 4.5 Application.
Adobe developer center.
Flex in a Week video training.
KenBuja
galechaung
My problem is solved by using the Adobe Flex 4.6 SDK.
Thank you very much!!!
KenBuja
You're welcome. Please remember to click the Mark as Answer check.
