Printing Problem with AlivePDF
9012
22
06-09-2010 12:43 PM
BradOleson
The continuing printing saga:
I've installed a sample print utility from this thread:
http://forums.esri.com/Thread.asp?c=158&f=2421&t=299883&mc=11#936860
The solution calls for 2 parts - installing a .Net piece on the server in IIS and then adding the Flex components to the Flex project.  Everything seems fine on the Flex side, but when I run the create PDF code from the Flex app there is an error in the .Net piece.
When run on a remote machine the attached Error1 page appears.  When I check the app URL on the server side, I get a little more detail, but still errors out, as shown in the Error2 attachment.
I sent the author an e-mail directly, but thought I'd post here as well to see if anyone knew right off if there was a fix.  I've already checked .Net versions and 3.5 is the installed / required version.  I've also created a separate app pool in IIS in case that was an issue (from reading online ASP .Net forums / blogs).
Anyone have any ideas?
Brad
by Anonymous User
Not applicable
Original User: FrankTT
Thank you, Robert. That did the trick.
jerrysalinas
Hello Guys,
I've been following the thread and I was wondering if there is a way to incorporate the addition of a Title and a Subtitle using textboxes. This was a feature I implemented in the previous version of the API for printing. Is this doable?
Thank you,
Jerry
by Anonymous User
Not applicable
Original User: TomLUX
Hy,
maybe this PrintSOE may be an alternative to the AlivePDF:
http://www.arcgis.com/home/item.html?id=6809086326ea4c76bf026a32bb9dd698
There exists already a simple FlexWidget.
Any suggestions/developer help are welcome.
Tom
