Printing Problem with AlivePDF
8958
22
06-09-2010 12:43 PM
BradOleson
The continuing printing saga:
I've installed a sample print utility from this thread:
http://forums.esri.com/Thread.asp?c=158&f=2421&t=299883&mc=11#936860
The solution calls for 2 parts - installing a .Net piece on the server in IIS and then adding the Flex components to the Flex project.  Everything seems fine on the Flex side, but when I run the create PDF code from the Flex app there is an error in the .Net piece.
When run on a remote machine the attached Error1 page appears.  When I check the app URL on the server side, I get a little more detail, but still errors out, as shown in the Error2 attachment.
I sent the author an e-mail directly, but thought I'd post here as well to see if anyone knew right off if there was a fix.  I've already checked .Net versions and 3.5 is the installed / required version.  I've also created a separate app pool in IIS in case that was an issue (from reading online ASP .Net forums / blogs).
Anyone have any ideas?
Brad
by Anonymous User
Not applicable
Original User: rscheitlin
Shafi,
   Just like the message is telling you you have to call this code directly from a mouse click like a button in a widget or a context menu. It can not be called from any other portion of code that call on another function before it opens the file save dialog.
AimeiChen
Shafi,
Hi, Robert
I added button click to load the printPDF function, but I have to click the button twice to open the save as window. Is something wrong with that?
Amy
private function PrintPDF():void
    generatePDF();
    var fileReference:FileReference = new FileReference();
    fileReference.save(myPDF.save(Method.LOCAL,"",Download.INLINE,"myPDF.pdf"),"map.pdf");
by Anonymous User
Not applicable
Amy,
   The generate pdf function is taking the focus which forces you to have to click the button again to give the focus to the save method. You need to have a button for generate pdf and then then have the user click a button that only has the file reference code.
AimeiChen
Amy,
Got it, thank you so much.
by Anonymous User
Not applicable
Original User: FrankTT
I've been reading the latest threads regarding the PDF Prinitng widget, along with the latest Flex API. I've also implemented a PDF widget which utilizes Robert's code. Once the widget displays and I click "print pdf" I get the following errors:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at org.alivepdf.fonts::AFMParser/readAFM()[/Users/adobe/Desktop/AlivePDF/src/org/alivepdf/fonts/AFMParser.as:92]
at org.alivepdf.fonts::AFMParser/makeFont()[/Users/adobe/Desktop/AlivePDF/src/org/alivepdf/fonts/AFMParser.as:252]
at org.alivepdf.fonts::AFMParser()[/Users/adobe/Desktop/AlivePDF/src/org/alivepdf/fonts/AFMParser.as:53]
at org.alivepdf.fonts::EmbeddedFont()[/Users/adobe/Desktop/AlivePDF/src/org/alivepdf/fonts/EmbeddedFont.as:39]
I am using the latest AlivePDF.swc library, but I can't seem to troubleshoot the error. Looks like my application can't access the font file. Can you guys lead down the right track on this one.
Thanx
Frank
RobertScheitlin__GISP
Frank,
Here some code that may help:
[Embed(source='assets/arial.ttf', embedAsCFF='false', fontName='myArial', mimeType='application/x-font')]
   private var font1:Class;
var myCoreFont:IFont = new  CoreFont (FontFamily.ARIAL);
     myPDF.setFont(myCoreFont,8);
Of course this assumes you have the arial.ttf in the assets folder of your project.
by Anonymous User
Not applicable
Robert,
I think that might be my problem. I commented this section of code due to errors during compilation.
/*    [Embed(source='assets/arial.ttf', embedAsCFF='false', fontName='myArial', mimeType='application/x-font')]
   [Embed(source='assets/esri_40.ttf',  mimeType="application/octet-stream")]
   private var fNorthArrow:Class;
   [Embed(source='assets/esri_40.ttf', embedAsCFF='false', fontName='esriNorth', mimeType="application/x-font")]
   private var fNorthArrowFont:Class;
   [Embed(source="assets/b617d5849ea5bacc44c29fc0d4c2bed6_esri_40.afm", mimeType="application/octet-stream")]
   private var afmNorthArrow:Class;   */
How can I get a hold of these missing .ttf files or is there a work around?
Thanx.
Frank,
  You should be able to search your machine and find these in the windows fonts folder.
by Anonymous User
Not applicable
Thanks Robert.
The only error now is referring to esri_40.afm. I could not find that one.
Frank,
   I forgot that I had to create that one.
