Prevent infowindow from popping up
1193
07-20-2012 10:26 AM
AaronNash
Is there a way to stop the info window from popping up when editing. I am developing a mobile application and no matter what I do the infowindow pops up. I can put my attribute inspector in a bordercontainer and and edit the data there, but that pop-up still occurs. I have tried using map.infoWindow.hide() with no success. I am using the 3.0 API
MehulChoksey
If you are using editor component of the flex API, then its not possible to prevent infowidow from showing up.
AaronNash
I am using the editor component,
thanks,
  Aaron
