popupskinrenderer is causing double encoding, how do i make it not encode?
3665
10-21-2016 08:08 AM
BobbySells
I don't want to use different fields for the same link. I write the %20 url's with a script and that makes them work with all of the other tools except popups.  I would greatly appreciate any help on this as it is more than nuisance level now.
if (htmlText)
fieldValue = new RichEditableText();
// convert attribute field values that just contain URLs into links
var match:Array = htmlText.match(/^\s*((https?|ftp):\/\/\S+)\s*$/i);
if (match && match.length > 0)
htmlText = '<a href="' + match[1] + '" target="_blank">' + match[1] + "</a>";
setTextFlow(fieldValue, htmlText);
fieldValue.editable = false;
fieldValue.left = "col2:5";
fieldValue.right = 0;
fieldValue.top = fieldLabel.top;
keyValueGroup.addElement(fieldValue);
RobertScheitlin__GISP
Bobby,
   I have not been coding in Flex for a couple of years now... I vaguely remember this issue and I don't think I ever found a solution for it.
