Pop-Up Configuration for Tiled Map Service
2557
05-02-2012 07:40 AM
by Anonymous User
Not applicable
Is it possible to set a pop-up configuration for a tiled map service?  I am trying to set up a pop-up for a feature layer that has multiple extents (sublayers), but have not found an example of how to make this work.
According to this help file, http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Pop_up_configuration_files/01m30000002..., setting up pop-ups should be possible, since "starting with version 2.3, the ArcGIS Viewer for Flex supports pop-ups windows for tiled and dynamic map services, as well as feature layers."
I know it can be easily done with a with a dynamic web service, which I have had success with, but I am not quite convinced it can be done with a tiled service.
So, can it be done???  If so, can someone provide an example of how the config and pop-up files are set up?
BTW I am currently using Flex Viewer 2.5.
Scott
MehulChoksey
