Placing an image on the ESRI map
1687
09-11-2013 05:02 AM
JustinSmyth
Is there a simple way to just put an image on the map, without using a KMLLayer or WMSLayer or using the ArcGIS server?  We have our own server that has images on it, just want to put them on the map.  Thanks.
RobertScheitlin__GISP
Justin,
  Simple... Mybe not... But there is a way in the API. Looks at the docs for the MapImage
https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/layers/supportClasses/MapImage.html
JustinSmyth
Thanks....do you happen to have an example with that class?  Any idea if using plain old DynamicServiceLayer would work?  Was going to try that next.
Justin,
  You can always add the geo-referenced image to a map and publish that map as a map service.
Here is a sample that adds a geo-refernced image to the map.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:esri="http://www.esri.com/2008/ags"
               pageTitle="NWS Radar Image Map">
    <fx:Script>
        <![CDATA[
            import com.esri.ags.events.MapEvent;
            import com.esri.ags.layers.MapImageLayer;
            import com.esri.ags.layers.supportClasses.MapImage;
            import spark.formatters.DateTimeFormatter;
            private var _mapImage:MapImage;
            [Bindable] private var _Region:Array;
            [Bindable]
            private var vRegion:String;
            private var eXmin:Number;
            private var eYmin:Number;
            private var eXmax:Number;
            private var eYmax:Number;
            private var lDate:String;
            private var rdate:Date;
            private var dateFormatter:DateTimeFormatter;
            public static const UPPERMISSVLY:Array = ["uppermissvly",-9965455.3476,4243023.8602,-11645922.8435,6438891.8024];
            protected function map_loadHandler(event:MapEvent):void
                dateFormatter = new DateTimeFormatter();
                dateFormatter.dateTimePattern = "yyyyMMdd_HHmm";
                var now:Date = new Date();
                rdate = new Date(now.setMinutes(8));
                //Adjust to UTC
                rdate.minutes += rdate.timezoneOffset;
                rdate = dateAdd("hours", -3, rdate);
                var sdate:String = dateFormatter.format(rdate.toString());
                _Region = UPPERMISSVLY;
                vRegion = _Region[0];
                eXmin = _Region[1];
                eYmin = _Region[2];
                eXmax = _Region[3];
                eYmax = _Region[4];
                var mapImageExtent:Extent = new Extent(eXmax,eYmin,eXmin,eYmax, map.spatialReference);
                _mapImage = new MapImage();
                _mapImage.source = "http://radar.weather.gov/ridge/Conus/RadarImg/" + vRegion + "_" + sdate + "_N0Ronly.gif";
                _mapImage.extent = mapImageExtent;
                var mil:MapImageLayer = new MapImageLayer();
                mil.add(_mapImage);
                map.addLayer(mil);
            private static function dateAdd( datePart:String, number:Number, date:Date ):Date {
                var _returnDate:Date = new Date( date );
                _returnDate[ datePart ] += number;
                return _returnDate;
    </fx:Script>
    <fx:Declarations>
        <esri:Extent id="initialExtent"
                     xmin="-9965455.3476" ymin="4243023.8602" xmax="-11645922.8435" ymax="6438891.8024">
            <esri:SpatialReference wkid="102100"/>
        </esri:Extent>
    </fx:Declarations>
    <s:controlBarContent>
        <s:RichText width="100%">
            This sample demonstrates how to add an geo-refernced image to the map.
        </s:RichText>
    </s:controlBarContent>
    <esri:Map id="map" extent="{initialExtent}" wrapAround180="true" load="map_loadHandler(event)">
        <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
    </esri:Map>
</s:Application>
JustinSmyth
Thanks for that example, MapImageLayer worked for what I wanted to do.
Justin,
   Glad I could help. Now it is your turn.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
