Passing variables from external html page
1933
10-19-2010 04:59 AM
CaseyBentz
Hello all,
I am working in adding Google Street View to my Flex application. I have it working as browser popup.  What I would like is for this browser to pass back the current lat/lon to my Flex application.  I have attempting to incorporate some code that I found, but it looks like it only works when the swf is embedded in the same page as the JavaScript.  Does anyone know how/if this can be done?
BjornSvensson
Esri Alum
There is an API sample that shows how to support URL parameters like ReadURL.html?ll=37.063,-95.677&scale=500000
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=ReadURL
CaseyBentz
So, this really won't work for what I am doing.  What I am doing is opening a popup to display Google Street View data.  As the user clicks down a road, I want to have a graphic move on the map.  So, what I am thinking is that the popup will pass the lat/lon to the flex app.  I am pretty close, but I don't really like what I have to do to make it work.  I get the lat lon back in my index.template.html and it shows the alert. But, I don't know how to get that in my flex application.
Google Street Map Popup Window
[HTML]
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=utf-8"/>
<title>Street View</title>
<link href="http://code.google.com/apis/maps/documentation/javascript/examples/standard.css" rel="stylesheet" type="text/css" />
<script src="http://maps.google.com/maps/api/js?sensor=false" type="text/javascript"></script>
<script type="text/javascript">
  var position = "";
  function initialize() {
    lat = getParams('lat');
    lng = getParams('lng');
    var loc = new google.maps.LatLng(lat,lng);
    var panoramaOptions = {
      position: loc,
      pov: {
        heading: 34,
        pitch: 0,
        zoom: 1
      visible: true
    var panorama = new  google.maps.StreetViewPanorama(document.getElementById("pano"),panoramaOptions);
    google.maps.event.addListener(panorama, 'position_changed', function() {
        var positionCell = document.getElementById('position_cell');
        positionCell.firstChild.nodeValue = panorama.getPosition();
position = positionCell.firstChild.nodeValue;
        sendLatLon(position);
  function getParams( name ){
name = name.replace(/[\[]/,"\\\[").replace(/[\]]/,"\\\]");
var regexS = "[\\?&]"+name+"=([^&#]*)";
var regex = new RegExp( regexS );
var results = regex.exec( window.location.href );
if( results == null )
  return "";
else
  return results[1];
function sendLatLon(position)
  //Send the lat lon back to the parent window
  window.opener.callBack(position);
</script>
</head>
<body onload="initialize()">
  <div id="pano" style="width: 100%; height: 640px;z:index: 0"></div>
  <div id="footer" style="height:30px;">
If no image appears StreetView is not available
  </div>
  <div id="panoInfo" style="width: 425px; height: 240 px;float:left">
  <table>
  <tr>
    <td><b>Position</b></td><td id="position_cell"> </td>
  </tr>
  </table>
  </div>
</body>
</html>
[/HTML]
Function from my index.template.html
var flexParams = "latlon=";
function callBack(latlon){
   flexParams = "latlon=" + latlon;
   alert(flexParams);
Function that I use to display the street view popup.
private function mouseDownHandler(e:MapMouseEvent):void
 Model.instance.streetViewVis = true;
 var mapPoint:MapPoint = WebMercatorUtil.webMercatorToGeographic(e.mapPoint) as MapPoint;
 var lng:String = mapPoint.x.toFixed(13);
 var lat:String = mapPoint.y.toFixed(13);
 // launch street view
 var url:String  = "StreetView.html?lat=" + lat + "&lng=" + lng;
 var window:String = "StreetView";
 var features:String = "toolbar=no,location=no,resizable=no,directories=no,status=no,scrollbars=no,copyhistory=no,width=610,height=700";
 var WINDOW_OPEN_FUNCTION : String = "window.open";
 ExternalInterface.call( WINDOW_OPEN_FUNCTION, url, window, features );
CaseyBentz
I finally got this figured out.  I will share my code when I have all the bugs worked out.  I added a callback function to my flex code, and that made all the difference.
FrankRoberts
Don't know if this will help, but I've got some code you can look at in my Street View and more widget at:
http://www.arcgis.com/home/item.html?id=dc56d2ab11534d24a5559ea9dc8f5119
CaseyBentz
I am about to roll this functionality into my application on my test server. I thought I would share what I did. I have attached the files I used.
