tooltip bug
848
10-20-2010 04:34 AM
philippschnetzer
when using floating widgets as preload="minimized" the tooltip on the widget icon does not appear when the map is loaded until the widget is maximized once and then minimized.  After it is maximized once the tooltip appears without issue.
MehulChoksey
thanks for reporting. This will be fixed in Next release.
