Passing Parameters in Network Service
2363
11-12-2011 04:11 AM
tommykurniawan
Hi All,
I have problem on passing attribute parameters in network service,
Refer to REST info like this :
Network Layer: Define_Standby_Areas
Layer Type: esriNAServerServiceAreaLayer
Impedance: TravelTime
Restrictions: vGroup
Accumulate Attribute Names:
Attribute Parameter Values:
    Attribute Name: TravelTime
    Parameter Name: vSpeed
    Parameter Value: 15
I try to pass some value for traveltime.vspeed ( for example default value 15 )
   private var Apv:Array = new Array([{AttributeName: "TravelTime",
    ParameterName: "vSpeed",
    ParameterValue: 15}]);
</fx:Script>
<fx:Declarations>
  <esri:ServiceAreaTask id="saTask"
    concurrency="last"
    fault="faultHandler(event)"
    requestTimeout="30"
    showBusyCursor="true"
    solveComplete="solveCompleteHandler(event)"
  url="http://server/ArcGIS/rest/services/VRN_ND2/NAServer/Define_Standby_Areas"/>
  <!--attributeParameterValues="{['TravelTime','vSpeed',15]}"-->
  <!--attributeParameterValues="{['TravelTime','vSpeed','15']}"-->
  <esri:ServiceAreaParameters id="saParams"
    attributeParameterValues="{[Apv]}"
    defaultBreaks="{[30]}"
    outSpatialReference="{myMap.spatialReference}"
I already try several methods, and still not applicable.
Could someone give advice for this ?
RobertScheitlin__GISP
Tommy,
  This is not tested:
        <esri:ServiceAreaParameters id="saParams" defaultBreaks="{[30]}" outSpatialReference="{map.spatialReference}">
            <esri:attributeParameterValues>
                <esri:AttributeParameterValue attributeName="TravelTime" parameterName="vSpeed" parameterValue="15" />
            </esri:attributeParameterValues>
        </esri:ServiceAreaParameters>
tommykurniawan
Hi Robert,
I put in complete code like this
   outputPolygons="esriNAOutputPolygonDetailed"
   returnFacilities="false"
   splitPolygonsAtBreaks="false">
Flash Builder pass it, and flash player debugger pass it,
but the error comes out like this
Service Area Error 400
Unable to complete  operation.
'attributeParameterValues' parameter is invalid
Parameters could not be transfered to the services.
I should try other way.
Anyway Thank You for this reply.
tommykurniawan
Just for sharing,
The solution is, by putting action script code
  var attparamsval:AttributeParameterValue = new AttributeParameterValue();
  attparamsval.attributeName = "TravelTime";
  attparamsval.parameterName = "vSpeed";
  attparamsval.parameterValue = "16";
  var attrParamVal:Array = new Array();
  attrParamVal.push(attparamsval);
  saParams.attributeParameterValues = attrParamVal;
Thanks
