Null pointers with snapping in draw/edit tool
1138
04-19-2011 12:34 AM
LukeEvans
I am getting the following error whenever trying to use snapping in the draw or edit tool
TypeError: Error #1009: Cannot access a property or method of a null object reference.
 at com.esri.ags.tools::DrawTool/checkForSnapping()
 at com.esri.ags.tools::DrawTool/map_mouseMoveFirstHandler()
We are using the BNG (27700) co-ordinate system.
Is there anything on the server that needs to be enabled for us to be able to snap in Flex?
Thanks
Luke
LukeEvans
There appears to be a problem when using our map data.  It works fine when plugging in esri services.  I'll update this if we manage to find any solution to this issue
BjornSvensson
Esri Alum
Snapping does not work for non-geographic, non-webmercator projections.  We will add support for this in an upcoming 2.3.1 release.
