Not able to see services created on my machine in another computer
807
08-23-2012 07:17 AM
ionarawilson1
I have a web application that has ESRI services and services I created on my machine. I want users in the same building to view my application. I used instructions to deploy the website by going to the IIS manager and adding an application to the default website of my machine name, having the physical path to be the folder where I exported the release build of my Flex application.
When I use my computer to view I can see the services I created on my machine, but when I use another computer I see the application and ESRI services but not the services I created. I have a crossdomain.xml file on the inetpub/wwwroot that has the following
 <?xml version="1.0"?> <!DOCTYPE cross-domain-policy SYSTEM "http://www.adobe.com/xml/dtds/cross-domain-policy.dtd"> <cross-domain-policy>     <site-control permitted-cross-domain-policies="all"/>     <allow-access-from domain="*"/> </cross-domain-policy>
Do you guys have any ideas why this is happening?
RobertScheitlin__GISP
Ionara,
   You need to get with your IT Dept as your Windows Firewall is likely blocking it, and an exception has to be added to the firewall.
Ionara,
ionarawilson1
You were right as always Robert! I went to Control Panel>System and Security>Windows Firewall>Allow a program or feature through a windows firewall
Then I checked the domain check box (they were unchecked)  for
World Wide Web Services (HTTP)
Web Management Service (HTTP)
Thanks again!!!
