MXD Background Color
1682
05-13-2010 06:40 AM
by Anonymous User
Not applicable
I've tried this several ways. Prolly missing something. I want the background color of the MXD to be a certain color other than white. If I set this in the MXD (e.g. frame color) the background in the map service is still white. I've even tried backgroundColor for the Map object but to no avail. Any ideas?
Thanks!
RGibson
Drew
I was able to change the color using Frame background property.
Here were my steps.
- Right Click on the data frame
- Select Properties
- Select "Frame" tab
- Change the background color
- Apply and save the MXD
- Restart the map service
- Clear the rest cache
Drew
by Anonymous User
Not applicable
Yup. Tried that as well. No luck. And you made this work in a DynamicMapServiceLayer, Drew?
Drew
Yes, its using a dynamic service.
I did some more testing and I almost thought I was going crazy because it was not working.
It seems to only work when the output format is JPG.
Make sure your layers ImageFormat is set to JPG
Drew
DasaPaddock
By default, the background is transparent. You can still use PNG if you turn the transparency off:
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/apiref/com/esri/ags/layers/ArcGISDynamicMa...
Drew
That explains why JPG was only working for me... Makes sense  🙂
