Multiple Static Images using the static image widget
1548
11-22-2010 08:16 PM
deleted-user-NnRwwd8ols89
i am trying to use the static image widget to display both a legend (in the top right) and my companies logo (in the bottom right) in the same map, and i have done this by using the static image widget and having 2 different StaticImageWidget.xml files, each one calling a separate image and placing them where i want them. they are named differently, and each called individually from the config.xml
however, for some reason this causes the application to constantly think it's loading, so the mouse cursor is always the spinning clock. Everything else works, other than the mouse cursor!
is there a way to call multiple static images?! i want to avoid merging all my logos etc into a single image as the placement won't be as exact as i want it
thanks
Ben
KamranKiyani
Hi Ben!
This is actually both xml are using the same swf file. To overcome this problem, make a duplicate folder of StaticImage with different name. You can also rename the xml file in new folder according to the folder name(optional). Call this file for 2nd image. Try it.
Kamran Kiyani
This is perfect, thanks so much, this will make using this so much more flexible!
Ben
RamonLeal_Pessoa
I have a problem like that.
I used the Static image widget to insert my company logo. Also, i have the Thematic Query Widget to display my Thematic Maps...
The problem is that: When the Thematic Query Widget is open, my company logo desapear.
What´s happening?
I know(think) that the Thematic Query Widget use any like the Static Image Widget to display the legend image...
Is there a conflict???
Any hint?
