Multiple combo box query
3003
08-26-2013 08:49 PM
DennisH
I have the following code that has two combo boxes to formulate a query. I am looking to add a third combo box to the mix.
I'm new to flex and working through it...can anyone be of assistance here?
Regards,
Dennis
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"       xmlns:mx="library://ns.adobe.com/flex/mx"       xmlns:esri="http://www.esri.com/2008/ags"       xmlns:s="library://ns.adobe.com/flex/spark"       pageTitle="Query Task (with a map)">    <s:layout>   <s:VerticalLayout gap="10"         horizontalAlign="center"         paddingBottom="20"         paddingLeft="25"         paddingRight="25"         paddingTop="20"/>  </s:layout>    <fx:Script>   <![CDATA[    import com.esri.ags.FeatureSet;    import com.esri.ags.Graphic;        import mx.collections.ArrayCollection;    import mx.controls.Alert;    import mx.events.IndexChangedEvent;    import mx.rpc.AsyncResponder;        import spark.events.IndexChangeEvent;        [Bindable] public var westStates:ArrayCollection = new ArrayCollection(['California','Arizona','Colorado','Washington','Oregon']);    [Bindable] public var eastStates:ArrayCollection = new ArrayCollection(['New York','Pennsylvania','Virginia','Illinois','Maine']);    [Bindable] public var southStates:ArrayCollection = new ArrayCollection(['Louisiana','Florida','Alabama','Mississippi','Texas']);    [Bindable] public var regions:ArrayCollection = new ArrayCollection(['West','East','South']);    [Bindable] public var statesArr:ArrayCollection = new ArrayCollection([westStates,eastStates,southStates]);        public function changeStates(event:IndexChangeEvent):void    {     var index:int = event.currentTarget.selectedIndex;     statesDDL.dataProvider = statesArr[index];     if(!statesDDL.enabled)     {      statesDDL.enabled = true;     }    }     private function doQuery():void    {     queryTask.execute(query, new AsyncResponder(onResult, onFault));     function onResult(featureSet:FeatureSet, token:Object = null):void     {      // No code needed in this simple sample, since the      // graphics layer is bound to the query result using      // graphicProvider="{queryTask.executeLastResult.features}"     }     function onFault(info:Object, token:Object = null):void     {      Alert.show(info.toString(), "Query Problem");     }    }   ]]>  </fx:Script>    <fx:Declarations>   <!-- Layer with US States -->   <esri:QueryTask id="queryTask"       showBusyCursor="true"       url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"       useAMF="false"/>      <esri:Query id="query"      outSpatialReference="{myMap.spatialReference}"      returnGeometry="true"      text="{statesDDL.selectedItem}">    <esri:outFields>     <fx:String>MED_AGE</fx:String>     <fx:String>POP2007</fx:String>    </esri:outFields>   </esri:Query>  </fx:Declarations>    <s:Panel height="60"     backgroundColor="0xB2BFC6"     title="Query a layer (search for a state)">   <s:layout>    <s:HorizontalLayout/>   </s:layout>   <s:DropDownList id="regionsDDL" width="150" prompt="Select a region" dataProvider="{regions}" change="changeStates(event)"/>   <s:DropDownList id="statesDDL" width="150" prompt="Select a country" enabled="false" change="queryBTN.enabled = true;"/>   <s:Button id="queryBTN" click="doQuery()" enabled="false" label="Do Query"/>  </s:Panel>    <esri:Map id="myMap">   <esri:extent>    <esri:Extent xmin="-14298000" ymin="2748000" xmax="-6815000" ymax="7117000">     <esri:SpatialReference wkid="102100"/>    </esri:Extent>   </esri:extent>   <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Physical_Map/MapServer"/>   <esri:GraphicsLayer id="myGraphicsLayer" graphicProvider="{queryTask.executeLastResult.features}"/>  </esri:Map>   </s:Application>
RobertScheitlin__GISP
Dennis,
   Here is a thrid dropdown added and it will only come into play when you choose South then Alabama and the third drop down with Alabama Counties will work. Hopefully you can glean from this code.
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"                xmlns:mx="library://ns.adobe.com/flex/mx"                xmlns:esri="http://www.esri.com/2008/ags"                xmlns:s="library://ns.adobe.com/flex/spark"                pageTitle="Query Task (with a map)">          <s:layout>         <s:VerticalLayout gap="10"                           horizontalAlign="center"                           paddingBottom="20"                           paddingLeft="25"                           paddingRight="25"                           paddingTop="20"/>     </s:layout>          <fx:Script>         <![CDATA[             import com.esri.ags.FeatureSet;                          import mx.collections.ArrayCollection;             import mx.controls.Alert;             import mx.rpc.AsyncResponder;                          import spark.events.IndexChangeEvent;                          [Bindable] public var westStates:ArrayCollection = new ArrayCollection(['California','Arizona','Colorado','Washington','Oregon']);             [Bindable] public var eastStates:ArrayCollection = new ArrayCollection(['New York','Pennsylvania','Virginia','Illinois','Maine']);             [Bindable] public var southStates:ArrayCollection = new ArrayCollection(['Louisiana','Florida','Alabama','Mississippi','Texas']);             [Bindable] public var regions:ArrayCollection = new ArrayCollection(['West','East','South']);             [Bindable] public var statesArr:ArrayCollection = new ArrayCollection([westStates,eastStates,southStates]);             [Bindable] public var alabamaCounties:ArrayCollection = new ArrayCollection(['Autauga','Baldwin','Barbour','Bibb','Blount','Bullock','Butler','Calhoun','Chambers','Cherokee','Chilton','Choctaw','Clarke','Clay','Cleburne','Coffee','Colbert','Conecuh','Coosa','Covington','Crenshaw','Cullman','Dale','Dallas','De Kalb','Elmore','Escambia','Etowah','Fayette','Franklin','Geneva','Greene','Hale','Henry','Houston','Jackson','Jefferson','Lamar','Lauderdale','Lawrence','Lee','Limestone','Lowndes','Macon','Madison','Marengo','Marion','Marshall','Mobile','Monroe','Montgomery','Morgan','Perry','Pickens','Pike','Randolph','Russell','St. Clair','Shelby','Sumter','Talladega','Tallapoosa','Tuscaloosa','Walker','Washington','Wilcox','Winston']);                          public function changeStates(event:IndexChangeEvent):void             {                 var index:int = event.currentTarget.selectedIndex;                 statesDDL.dataProvider = statesArr[index];                 if(!statesDDL.enabled)                 {                     statesDDL.enabled = true;                 }             }                          private function doQuery():void             {                                  if (statesDDL.selectedItem == 'Alabama')                 {                     queryTask.url = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/4";                     query.where = "STATE_NAME = 'Alabama' AND NAME = '" + countiesDDL.selectedItem + "'";                 }                 queryTask.execute(query, new AsyncResponder(onResult, onFault));                 function onResult(featureSet:FeatureSet, token:Object = null):void                 {                     // No code needed in this simple sample, since the                     // graphics layer is bound to the query result using                     // graphicProvider="{queryTask.executeLastResult.features}"                 }                 function onFault(info:Object, token:Object = null):void                 {                     Alert.show(info.toString(), "Query Problem");                 }             }                          protected function statesDDL_changeHandler(event:IndexChangeEvent):void             {                 if (statesDDL.selectedItem == 'Alabama')                 {                     countiesDDL.dataProvider = alabamaCounties;                     countiesDDL.enabled = true;                 }else{                     queryBTN.enabled = true;                     query.text = statesDDL.selectedItem;                 }             }                      ]]>     </fx:Script>          <fx:Declarations>         <!-- Layer with US States -->         <esri:QueryTask id="queryTask"                         showBusyCursor="true"                         url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"                         useAMF="false"/>                  <esri:Query id="query"                     outSpatialReference="{myMap.spatialReference}"                     returnGeometry="true">             <esri:outFields>                 <fx:String>MED_AGE</fx:String>                 <fx:String>POP2007</fx:String>             </esri:outFields>         </esri:Query>     </fx:Declarations>          <s:Panel height="60"              backgroundColor="0xB2BFC6"              title="Query a layer (search for a state)">         <s:layout>             <s:HorizontalLayout/>         </s:layout>         <s:DropDownList id="regionsDDL" width="150" prompt="Select a region" dataProvider="{regions}" change="changeStates(event)"/>         <s:DropDownList id="statesDDL" width="150" prompt="Select a state" enabled="false" change="statesDDL_changeHandler(event)"/>         <s:DropDownList id="countiesDDL" width="150" prompt="Select a county" enabled="false" change="queryBTN.enabled = true;"/>         <s:Button id="queryBTN" click="doQuery()" enabled="false" label="Do Query"/>     </s:Panel>          <esri:Map id="myMap">         <esri:extent>             <esri:Extent xmin="-14298000" ymin="2748000" xmax="-6815000" ymax="7117000">                 <esri:SpatialReference wkid="102100"/>             </esri:Extent>         </esri:extent>         <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Physical_Map/MapServer"/>         <esri:GraphicsLayer id="myGraphicsLayer" graphicProvider="{queryTask.executeLastResult.features}"/>     </esri:Map>      </s:Application>
Dennis,
DennisH
Thank you Robert, greatly appreciated!
