MosaicRule Error
1587
04-12-2011 11:25 AM
SteveLi
I have following code to perform identify on MosaicDataSet.
var identifyParams:ImageServiceIdentifyParameters = new ImageServiceIdentifyParameters();
    identifyParams.geometry = event.mapPoint;
    identifyParams.mosaicRule = new MosaicRule();
    identifyParams.mosaicRule.where = "Name = 'WinTemp_1950_01'"
identifyTask.execute(identifyParams, new AsyncResponder(myResultFunction, myFaultFunction));
The code gives me error:
[RPC Fault faultString="Unable to complete  operation." faultCode="400" faultDetail="Invalid value for parameter 'mosaicRule'"]
I believe the issue is I have to initialize all members of MosaicRule.  I think this is a bug in Flex API.  Can someone confirm?
Thanks.
MehulChoksey
Yes this is a bug. This will be fixed in upcoming release.(2.3)
SteveLi
Thanks for the reply.
Is there a workaround?  what default value should I give to other members if I don't want to set them?
when is the 2.3 release?
MehulChoksey
workaround would be create key-value pairs of the parameters that you want to set, Url encode it and then pass those along as queryparameters:
e.g.:
<esri:ArcGISImageServiceLayer url="http://myserver/ArcGIS/rest/services/Test/ImageServer?mosaicRule=%0A%7B%22mosaicMethod%22%3A%22esriM..." imageFormat="jpgpng" />
