Modified  Indentify Widget
806
04-08-2011 06:08 AM
RafaelMiranda
Robert
I modified the widget identify, I put a combobox with him and my layer according to my directoy services also created a tag in xml <excludeLayer>, another thing that I have also created
this function this.LoadCombo ();
in my case I needed to identify each layer separated by choosing the combobox
RobertScheitlin__GISP
Rafael,
   I am a pretty nice and generous guy with my time and my skill... But I can not be every ones FREE private developer. I will support my widgets if they have errors and I will entertain requests for enhancements but if you want to modify my widgets to do something unique to your needs than by all means that is what the source code is there for. Having said that if you have a more specific question about an area you are stuck on after trying, then ask away and if time permits I will try and respond.
RafaelMiranda
My need was to put every layer within a combox and clicking on the map will identify it according to my combobox, what I did was for you to have some idea or improvement on the widget, if I caused any problems I'm sorry
You could improve this idea. What do you think?
