MiniSearch widget doesnt work execSearch()
6396
44
07-05-2010 05:40 AM
NatashaManzuiga
http://forums.esri.com/Thread.asp?c=158&f=2421&t=295623#953276
I have the same problem...execSearch()..in MiniSearch widget.
If I add a search term and press Return nothing happens. I also added a button to the widget with the "execSearch()" statement and nothing happens with this either.
Thx
Naty
NatashaManzuiga
Thx
Naty
This is the Error #1010 I got...in this part of the function execSearch():
catch (error:Error)
      trace(error.message, false);
RobertScheitlin__GISP
Natasha,
   Did you follow these directions?
1. Add MiniSearch.mxml & MiniSearch.xml to the src/com/esri/solutions/flexviewer/widgets folder
2. Add xmlns:widgets       ="com.esri.solutions.flexviewer.widgets.*" to the application tag in the index.mxml.
3. Add <widgets:MiniSearch x="20" y="420" /> to the index.mxml just above the </mx:Application> and below the  </SiteContainer>  so the last three lines of the index.mxml would look like this
</SiteContainer>
</mx:Application>
NatashaManzuiga
Natasha,
</SiteContainer>
</mx:Application>
Thanks Robert.
I had problem with query.outFields and now it works very well...could I show some info window with data, image and links after this MiniSearch...?
Naty
Naty,
     The minisearch was only designed to zoom you to a location quickly. if you want the info popup then you should use the full search widget or you would have to extend the code to add the info popup.
NatashaManzuiga
Naty,
Many thanks Robert I will try to do it ..
Naty
NatashaManzuiga
Naty
Robert, mini search works perfectly, after this I tried to use the search widget function that I got from timerComplete of MapManager.mxml so I created a new function in MiniSearch.mxml
   private function execSearch1():void
    try
    var id:Number = SiteContainer.getInstance().getWidgetId("Search");
    var bWidget:IBaseWidget = SiteContainer.getInstance().widgetManager.getWidget(id) as IBaseWidget;
     if (bWidget){
      var bWidg:BaseWidget = bWidget.getInstance();
      var vSW:SearchWidget = bWidg as SearchWidget;
      vSW.querybmpid(ti.text);
     } else {
      //execSearch();
      var bWidget2:IBaseWidget;
      bWidget2 = SiteContainer.getInstance().widgetManager.getWidget(id) as IBaseWidget;
      var vSW2:SearchWidget = bWidget2 as SearchWidget;
      vSW2.querybmpid(ti.text);
    catch (error:Error)
      //execSearch();
      ti.text = error.message;
It perfectly works tooo....but after I Load another widget(for example: LiveMapsWidget.swf) it stops to work and I get Error #1010...how is it possible?...
Naty
NatashaManzuiga
    try
     if (bWidget){
     } else {
      //execSearch();
    catch (error:Error)
      //execSearch();
Naty
Nobody Can Help me? 😞
Naty,
   Can you explain in more detail what you are attempting to do?
NatashaManzuiga
Naty,
If u see my code, I modified your code to use SearchWidget function...
it's very nice I can search things immediately with MiniSearch widget...
but after I load another widget it doesnt work anymore...it seems like it doesnt recognize the SearchWidget anymore SearchWidget or something changed with ID of the widgets...
Ohhhh u came back Robert ... I feel much better 😄
Naty
