May service layers
989
06-18-2013 12:16 PM
NadeemQazi
I have a published a May service consisting of many layers on ARCGIS Server. I want to access from flex application the layers array of this map service in order to assign this layer array to esri legend control in flex application. Is there any way to access the layers in the published map services. please note I am using flex API under flash builder 4.6. Any advice.
regards
nadeem
JoeHewitt
getAllDetails: http://resources.arcgis.com/en/help/flex-api/apiref/index.html?com/esri/ags/layers/supportClasses/Al...
can return a layersDetails which is an array of detailed information about each layer in a map service.
Example:
myMayService.getAllDetails( new AsyncResponder(
function myAllResultFunction(result:AllDetails, token:Object = null):void
layerDetails = new ArrayCollection(result.layersDetails);
function myFaultFunction(error:Object, token:Object = null):void
Alert.show(String(error));
But to assign it your legend should automatically happen when you check the layers on assuming you have already added your service.
