MapProgressBar widget  for SFV 2.0
5109
9
08-03-2010 05:31 AM
ChenJuequan
HI
    I just created a widget that mimics the behavior of MapProgressBar in ArcGIS Server Sliverlight Api. This widget can only be used for SFV 2.0 now. Add this widget to your project and configure it in config.xml just like SFV's OverviewMapWidget.
Something like this:
<widget left="300" bottom="10" config="" url="widgets/MapProgressBar/MapProgressBarWidget.swf"/>
   I did not test this widget strictly, and I am sure this widget is not good enough, please give me your feedbacks. Sorry for my poor English.
   See attachment.
MLowry
Seems to be working well for me.
Thanks for the code!
DanielOchoa
Hello - First, let me say that I'm very new to SFV 2.0. Pardon my ignorance. but maybe I can learn how everything works if someone can answer this post.
I see how the OverviewMapWidget is configured under the UI elements:
<widget right="1" bottom="1" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/>
...as it calls on an XML and a SWF in order to work, but the data in this zip for this tool is an mxml.  How do you impliment this correctly?
I tried this:
<widget left="300" bottom="10" config="widgets/MapProgressBar/MapProgressBarWidget.mxml"/>
...But it didnt work.  Again, I'm very new to this.  Does the mxml have to be converted to a swf?
Thanks!
ChenJuequan
I tried this:
Thanks!
Well, maybe I should have provided the compiled swf file along with the mxml file with source code.  The attachment includes the compiled swf file.
DanielOchoa
Thanks! Code works great...
Still learning that mxml=swf
~ D
HaroldBostic
Hello, Great widget.  how do I change the barColor?
Thanks in advance
MarkHorsell
Thanks in advance
I'm having the same problem. I have copied the "mx.skins.halo.ProgressIndeterminateSkin.as" but setting that as my skin class breaks the animation. I know this is more of a flex problem than anything else, but if anyone could post an example that would be great.
RobertScheitlin__GISP
Mark,
   The simple way is to set the chromeColor of the progressBar.
MikeMartin
Is there a compiled swf for FlexViewer 2.4?
RonaldWisner
Hello,
Has anyone developed a progress device (or recompiled this one) for Flex 3.0?
Ron
