Map Service not loading using Flex API
5347
10
01-26-2011 05:46 AM
VinayVyas
Hi Friends,
I am new to ArcGIS and ArcGIS server. I created a service and used the arcgis manager to deploy a web application. So far so good. My goal is to use my .mxd file and use flex to view it on a web page and design my custom interface to interact with it.
I used the code samples given online and ran it using my flash builder. These also work.
The issue is when I try to use the map URL of my local ArcGIS server in my flash builder, it does not work. I see a blank screen.
My Flex code
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
    layout="absolute"
    xmlns:esri="http://www.esri.com/2008/ags">
<esri:Map>
<esri:ArcGISImageServiceLayer url="http://8HGXXXX:8399/arcgis/services/My_Map/MapServer" />
</esri:Map>
</mx:Application>
I shall be thankful if you can suggest me how to resolve this.
PS: The numbers have been censored for security.
RobertScheitlin__GISP
Vinay,
The issue is that you do not have "rest" in your url.
http://8HGXXXX:8399/arcgis/rest/services/My_Map/MapServer
VinayVyas
Hi Robert,
Thanks for the suggestion but it did not work.
The URL displayed is different in my arcgis manager, there is no "rest" in it.
This is a local map(mxd), created a service with the existing URL and I believe the maps online have the 'rest' directory.
Is there anything else that might be wrong?
Vinay
VinayVyas
Hi Robert,
I am surprised, if I browse the URL formed by the addition of rest, then it does navigate to a page containing information. I am not sure why it is not working in Flex.
It works with the sample code online.
here is my code again, do you find anything else wrong with it?
    layout="absolute"
<esri:Map>
<esri:ArcGISImageServiceLayer url="http://8HGXXXX:8399/arcgis/rest/services/map/MapServer" />
</esri:Map>
</mx:Application>
Vinay
DasaPaddock
VinayVyas
Hi Dasa,
Its still not working. I am surprised what the problem is, it is showing similar behavior using the Javascript API. The map is also error-free.
Vinay
DasaPaddock
Can you try a tool like HttpFox to see if it's trying to load: http://8HGXXXX:8399/crossdomain.xml
Also, see if any other requests are failing.
AndyGup
ScottEvenson
Hi Robert,
    layout="absolute"
<esri:Map>
</esri:Map>
</mx:Application>
Vinay
Vinay, you may have already solved this, but if you add /0 at the end of the url it might work.
so yours would look like: url="http://8HGXXXX:8399/arcgis/rest/services/map/MapServer/0" />
-Scott
Scott,
   Before you post this on other threads you need to understand that adding the /0 to the end of the url basically is saying use the first layer of the map service that is specified in the url. An ArcGISDynamicMapServiceLayer does not support the specification of a specific layer in it's url. A FeatureLayer however does support this as well as a QueryTask that is expecting an individual layer of a map service to be specified.
