Map Layers On/Off for Multiple Map Services
1141
08-24-2010 03:23 PM
AmySmith
Hello,
I'm interested in an interface feature that would allow users to check map layers on and off, much like this example - http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=Dynamic_TOC - but with a data grid fed by various dynamic and tiled map service layers. Does anyone have any thoughts on how to carry this out using the API for Flex?
Take care,
Amy Smith
AmySmith1
Hello!
If anyone's interested, I was able to develop a data grid component that allows the user to turn map layers on and off, sourcing from multiple tiled and dynamic map services (with a good kick start by the example I linked to in my previous post - thanks!).
For the Data Grid
<?xml version="1.0" encoding="utf-8"?>
<mx:DataGrid xmlns:fx="http://ns.adobe.com/mxml/2009"
    xmlns:s="library://ns.adobe.com/flex/spark"
    xmlns:mx="library://ns.adobe.com/flex/mx"
    creationComplete="populateArray()">
 <fx:Script>
  <![CDATA[
   import com.esri.ags.Map;
   import com.esri.ags.layers.ArcGISDynamicMapServiceLayer;
   import com.esri.ags.layers.ArcGISTiledMapServiceLayer;
   import com.esri.ags.layers.Layer;
   import com.esri.ags.layers.supportClasses.LayerInfo;
   import mx.collections.ArrayCollection;
   import mx.controls.Alert;
   import mx.utils.ObjectUtil;
   private var _map:Map;
   private var dp:ArrayCollection = new ArrayCollection();
   public function get map():Map
    return _map;
   public function set map(value:Map):void
    _map = value;
   private function populateArray():void
    var NumLayers:int = _map.layerIds.length;
    var mapLayer:Layer = new Layer();
    var layerInfos:Array = new Array();
    for (var i:int=0; i<NumLayers; i++)
     mapLayer = (_map.getLayer(_map.layerIds));
     if (mapLayer.className == 'ArcGISDynamicMapServiceLayer')
      layerInfos = ArcGISDynamicMapServiceLayer(mapLayer).layerInfos;
      var infoArrayLength:int = layerInfos.length;
      for (var n:int; n<infoArrayLength; n++)
       dp.addItem({name: layerInfos.name, defaultVisibility: layerInfos.defaultVisibility, mapType: mapLayer.className, mapID: mapLayer.id, layerID: layerInfos.id});
     else if (mapLayer.className == 'ArcGISTiledMapServiceLayer')
      dp.addItem({name: mapLayer.id, defaultVisibility: mapLayer.visible, mapType: mapLayer.className, mapID: mapLayer.id})
    setDataProvider();
   private function setDataProvider():void
    dataProvider = dp;
   public function showLayer(layerIndex:int):void
    if (dp[layerIndex].mapType == 'ArcGISTiledMapServiceLayer')
     _map.getLayer(dp[layerIndex].mapID).visible = true;
    else if (dp[layerIndex].mapType == 'ArcGISDynamicMapServiceLayer')
     var visibleLayers:ArrayCollection = (ArcGISDynamicMapServiceLayer(_map.getLayer(dp[layerIndex].mapID)).visibleLayers)
     visibleLayers.addItem(dp[layerIndex].layerID);
   public function hideLayer(layerIndex:int):void
     _map.getLayer(dp[layerIndex].mapID).visible = false;
     var idIndex:int = visibleLayers.getItemIndex(int(dp[layerIndex].layerID));
     if (idIndex != -1)
      visibleLayers.removeItemAt(idIndex);
   private function removeBusyCursor(event:Event):void
    cursorManager.removeBusyCursor();
 </fx:Script>
 <mx:columns>
  <mx:DataGridColumn dataField="defaultVisibility" headerText="Visibility" width="70" itemRenderer="components.LayerVisibilityRenderer"/>
  <mx:DataGridColumn dataField="name" headerText="Layer Name"/>
 </mx:columns>
</mx:DataGrid>
For the Renderer
<mx:HBox xmlns:fx="http://ns.adobe.com/mxml/2009"
   xmlns:mx="library://ns.adobe.com/flex/mx" horizontalAlign="center"
   implements="mx.controls.listClasses.IDropInListItemRenderer">
 <fx:Script>
  <![CDATA[
  import mx.controls.listClasses.BaseListData;
  private var _listData:BaseListData;
  public function get listData():BaseListData
  return _listData;
  public function set listData(value:BaseListData):void
  _listData = value;
  private function clickHandler(event:MouseEvent):void
  var layerIndex:int = listData.rowIndex;
  if (cb.selected)
  LayerVisibility(listData.owner).showLayer(layerIndex);
  else
  LayerVisibility(listData.owner).hideLayer(layerIndex);
 </fx:Script>
 <mx:CheckBox id="cb" selected="{data.defaultVisibility}" click="clickHandler(event)"/>
</mx:HBox>
Have a lovely Wednesday!
- Amy Smith
tanyabisen
Hey Amy,
I am trying to implement your code.. just wanted to clarify if you could share the code with me so that I will be able to understand the process in a better manner.. I have a DynamicMapService and i want the one layer to be seen when the map loads alongwith its ON in TOC..and later user can turn ON other layers..
Can you please help me with this..I am a flex newbie and struggling big time to understand the things
Thanks
