map is not displayed in mxml file
1062
08-14-2012 05:24 AM
NadeemQazi
Hi
I created a map and published it as map service using ARCGIS Server and use this service using ARCGIS VIEWER. it works fine , i checked in config file and change the type from tiled to dynamic it worked fine in both cases. However when i used flex SDK under flush builder to access the same published map service it did not work. I tried both
ArcGISDynamicMapServiceLayer and  ArcGISTiledMapServiceLayer but it did not work either case. following is the code in mxml file.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:esri="http://www.esri.com/2008/ags"
      pageTitle="A tiled map service">
<esri:Map>
  <esri:ArcGISTiledMapServiceLayer url="http://localhost/ArcGIS_server/services/testwithflex/MapServer"/>
</esri:Map>
</s:Application>
Any suggestion
Regards
Nadeem
RobertScheitlin__GISP
Nadeem,
   Te reason it is not working is that you are not providing the REST url for your service...
<esri:ArcGISTiledMapServiceLayer url="http://localhost/ArcGIS_server/rest/services/testwithflex/MapServer"/>
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
NadeemQazi
Nadeem,
thnx rscheitlin , however i would appreciate if you can kindly also guide how to provide rest URL , I had copied that URL from server please let me know what is missing
Regards
NAdeem
NadeemQazi
Regards
NAdeem
thnx i understand it now and it works
thank you
Regards
Nadeem
Nadeem,
   You get the REST Url by going to the REST Service directory for your server.
