map.extent issue using webMercatorToGeographic utility method
1295
03-31-2011 03:17 PM
PayamPayandeh1
Hello,
I am trying to find the bounding box that I derived from the map.extent. Inside a Widget i have the following code:
var extent:Extent = map.extent;
if(map.spatialReference.wkid != 4326)
var geom:Geometry = extent as Geometry;
geom = WebMercatorUtil.webMercatorToGeographic(geom);
extent = geom as Extent;
var bbox:String = extent.xmin + "," + extent.ymin + "," + extent.xmax + "," + extent.ymax;
Alert.show( "bbox = " + bbox );
I zoom out where the whole world is showing and I would think I would get something very close to:
bbox = -180,-90,180,90
instead I get (not consistently):
bbox = 132.1875000001546,-89.10609998620168,-132.1875000001546,89.10609998620168
and if I move the map (which is the whole world), which is still smaller than the window it is positioned in I get:
bbox = -30.355906316675714,-89.15909109779587,65.26909368301506,89.04976985003408
Does anyone have any ideas what I am doing wrong, I am new to GIS, not programming though.
Thanks in advance.
PayamPayandeh1
Ok, so after looking at the output when zoomed in closer, like at the continental level and closer, it seems to be producing the correct lat/lon extents. Its only when the whole world is exposed that it starts generating incorrect results.
ScottErwin
I am seeing this same issue.  Did you ever find a solution??
PayamPayandeh
I needed the values to generate queries passed to a web service, so this might not be a solution to what you are trying to do, but I basically check the value and truncate if its outside of the allowed values.
public function getMinLat() : String
    var ext:Extent = map.extent as Extent;
    if (ext.ymin < -90 ){
        return "-90"
    } else {
        return String(ext.ymin)
public function getMaxLat() : String
    if (ext.ymax > 90 ){
        return "90";
    } else {
        return String(ext.ymax)
public function getMinLon() : String
    if (ext.xmin < -180 ) {
        return "-180";
    } else {
        return String(ext.xmin)
public function getMaxLon() : String
    if ( ext.xmax > 180) {
        return "180";
    } else {
        return String(ext.xmax)
I hope this helps,
-Payam
