Login Page The connect to LDAP
830
04-28-2010 12:03 PM
HeatherHainsworth
I was wondering if anyone out there has ever tried to build a login page for a flex application (specifically the sample viewer) that connects to a LDAP server.
I have been trying to work with PHP and creating a PHP script that connects to LDAP and that flex calls as a service. But so far I have not been successful. Unfortunately I have no background in PHP and I think my problem is I am missing the PHP LDAP extension.
Anyway, any ideas anyone has would be great, if there are better ways than PHP I will take those as well.
Heather
Sorry the title should say a login page that connects to LDAP.
ZahidChaudhry
We implemented that using PHP and it is working fine. here is the url of app
http://gisonline.dep.wv.gov/trydam/
All you need to do is create two states one is application state and one login state. in Login state do a http service request using php and if php returns and authenticate username/pword, you can change state to application state else show alert or something...
I have seen with sample flex viewer same thing but never tried. You can add a titlewindow in the beginning of the app (so many people are using it for disclaimer so wont be hard to implement) that sends a http request and authenticate user..
HeatherHainsworth
My issue seemed to be with the PHP web service and getting it to connect to our LDAP Server. I had view states set up but the PHP service did not seem to be actually executing the PHP code. That being said I tried a different path and created a ASP.NET web service and it seems to be working so far.
Thanks for your response!
JamesKo
Hello hhainsworth,
I was wondering if you'd be willing to share your ASP.NET webservice code? This is something I've been looking into implementing on our website and your help would be greatly appreciated.
HeatherHainsworth
I ended up following this arcitlce to create the service http://msdn.microsoft.com/en-us/library/aa302397.aspx
So I created a empty C# Web Service in VS, and then used step 3 and step 5 of the walk through above to get the code. We don't have groups in the LDAP so I was able to ignore that. The hardest part was figuring out our parameters for the LDAP instance.
