Loading a local KMLLayer
902
09-09-2013 11:57 AM
JustinSmyth
Can you still only load a KMLLayer into the Flex ESRI map if it is a publicly available KML source?  I would like to load a KMLLayer on a private network.  Thanks.
BjornSvensson
Esri Alum
If you have "Portal for ArcGIS" on the private network, it would work.  Otherwise, it still need to be a public URL.
https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/layers/KMLLayer.html
