link from .Net to map
1163
03-01-2013 11:55 AM
HarryBoswell
I hope I'm asking this correctly - I'm new to Flex, and fairly new to ArcGIS in general.  I've developed a map and published it as a service.  It maps all complaints we've received, and identifies the status and some other information.  I can link from the complaint on the map back to the .Net web application.  But I would like to be able to link from the .Net application to the map and display that specific complaint and location.  I've tried using a URL like
"opc-dev1/CTS_map/?scale=18056&ll=033.262800,-090.590006&complaint_id=32961"
but that just brings up the full map with all the complaints displayed.  Is what I'm trying to do possible?
Harry
RobertScheitlin__GISP
Harry,
   What you are wanting to do is definitely possible but not without you writing code in your add to Query the Map service and display the result as a graphic or a FeatureLayer that is using selection mode. There are samples to get you going in the APIs samples section like this one:
http://resources.arcgis.com/en/help/flex-api/samples/01nq/01nq0000003q000000.htm
