Limit on the number of ArcGISDynamicMapServiceLayers that can be added?
1018
08-31-2011 12:34 PM
BrendanLee
I am working on a project now that could potentially need to have a large number of map layers added.
Not all layers will be visible at the same time and will turn on/off based on different user selections.
My question is, is there a limit on the number of layers that can be added to a map? Does the number of layers added affect performance?
Thanks!
KenBuja
MVP Esteemed Contributor
I remember seeing a post where a user ran into the maximum number of layers (around 20 or so) that could be added to a map, but I haven't been able to find the thread.
BjornSvensson
Esri Alum
No, there is no limit on the number of layers that be added to the map.
Yes, but not much.  What could affect performance if you have a lot of feature layers, especially with lots of highly detailed polygons.
YungKaiChin
Also, if you are pulling data from multiple large datasets, it could take a while (ranging a few seconds to a minute) to see them. Users may not know what is going on and are confused because nothing is happening.
