LayerTOC.mxml into ITitleWindow.mxml in custom web application
4376
11
01-24-2011 01:28 AM
francescodi_vito
Hi guys
i have developed a custom we application! I have developed a ITitleWindow with method PopUp, so i can call a panel with a button click. Now i would like to insert in tih ITitleWindow a LayerTOC.mxml so i can open and close my services in this panel.
This thing can be done?......in the TitleWindow i have to put in the class Esri:Map and ArcgisDynamic service?
thanks
RobertScheitlin__GISP
Francesco,
    Here is a example of what you need to do:
<?xml version="1.0" encoding="utf-8"?>
<mx:TitleWindow
 xmlns="assets.*"
 xmlns:mx="http://www.adobe.com/2006/mxml"
 xmlns:esri="http://www.esri.com/2008/ags"
    xmlns:samples="com.esri.ags.samples.*"
 width="320"
 height="400"
 paddingLeft="10"
 paddingRight="10"
 paddingTop="10"
 paddingBottom="10"
    x="0"
    y="82"
    title="Table of Contents"
    dropShadowEnabled="true"
    dropShadowColor="Black"
    shadowDirection="right"
    shadowDistance="5"
    showCloseButton="true">
 <mx:Script>
        <![CDATA[
   import com.esri.ags.layers.ArcGISDynamicMapServiceLayer;
   import mx.controls.Alert;
   import com.esri.ags.samples.LayerTOC;
   import com.esri.ags.samples.LayerVizRenderer;
   [Bindable]
            public var layers:ArcGISDynamicMapServiceLayer;
    </mx:Script>
 <samples:LayerTOC id="toc" layer="{layers}" width="280"/>
</mx:TitleWindow>
francescodi_vito
Thanks Robert, but in the tag layer={layer}, i put in the "id" of my Dynamic Service?
Francesco,
   So when you call this component you pass in the layers var. Like this:
<mx:Application
    xmlns:samples="com.*"
    xmlns:local="*"
    layout="absolute">
 <mx:Script>
  <![CDATA[
   import mx.effects.Move;
   import mx.managers.PopUpManager;
   import flash.events.Event;
   private var dragPanel:TOCPanel;
   private function showDragWindow():void
    //optional display effect
    var move : Move = new Move;
    move.xTo = 100;
    move.yTo = 150;
    if (dragPanel == null)
     dragPanel = TOCPanel( PopUpManager.createPopUp(this, TOCPanel, false) );
     //listen for close event if youve enabled close button
     dragPanel.layers = myDynamicService;
     dragPanel.addEventListener( "close", dragPanel_close );
     PopUpManager.centerPopUp( dragPanel );
     move.play( [dragPanel] );
    else
     PopUpManager.addPopUp(dragPanel,this,false);
     dragPanel.visible = true;
   private function dragPanel_close(evt:Event):void
    PopUpManager.removePopUp(dragPanel);
 </mx:Script>
 <esri:Map>
        <esri:ArcGISDynamicMapServiceLayer
            id="myDynamicService"
            url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/{myURL.selectedItem}/MapServer"
            load="myDynamicService.defaultVisibleLayers(); showDragWindow();"/>
    </esri:Map>
 <mx:ComboBox id="myURL" selectedIndex="0" horizontalCenter="0">
        <mx:Array>
            <mx:String>Demographics/ESRI_Census_USA</mx:String>
            <mx:String>Demographics/ESRI_Population_World</mx:String>
            <mx:String>Specialty/ESRI_StateCityHighway_USA</mx:String>
            <mx:String>Specialty/ESRI_StatesCitiesRivers_USA</mx:String>
            <mx:String>Specialty/SuperTuesdaySample</mx:String>
            <mx:String>Louisville/LOJIC_LandRecords_Louisville</mx:String>
            <mx:String>Louisville/LOJIC_PublicSafety_Louisville</mx:String>
        </mx:Array>
    </mx:ComboBox>
    <mx:Button click="showDragWindow()" label="Show TOC" left="60"  />
</mx:Application>
francescodi_vito
ok. So if i want add in the titlewindow a Hslider for trasparency, i have to create in my application a new var for tag alpha?
Thanks
Francesco,
   It is just this simple:
<mx:TitleWindow
 xmlns="assets.*"
 width="320"
 height="400"
 paddingLeft="10"
 paddingRight="10"
 paddingTop="10"
 paddingBottom="10"
    x="0"
    y="82"
    shadowDistance="5"
 <mx:Script>
        <![CDATA[
   import com.esri.ags.layers.Layer;
   import com.esri.ags.Map;
   [Bindable]
            private var _layer:Layer;
   //set layer alpha
         private function setLayerAlpha():void
          layers.alpha = slider.value;
         private function sldrDataTipFormatter(value:Number):String
       return int(value * 100) + "%";
    </mx:Script>
    <mx:VBox verticalGap="0" width="100%" paddingLeft="6" paddingRight="6" paddingBottom="3" paddingTop="3">
  <mx:HSlider id="slider" minimum="0" maximum="1" width="100%" change="setLayerAlpha()"
   dataTipFormatFunction="sldrDataTipFormatter" liveDragging="true" value="{layers.alpha}"/>
 </mx:VBox>
</mx:TitleWindow>
francescodi_vito
Sorry Robert
but  in Title Window when i put in "layers" my id of Dynamic Service i have one error
Francesco,
   If you look at the code it is not expecting an id it wants an actual ArcGISDynamicMapServiceLayer object.
francescodi_vito
aaah ok 🙂
I understand Robert
Thanks thanks
francescodi_vito
Robert but if a id is not expecting in this case i have to use one WMS with more layers. But if i want to put in Title window more layerTOC with one WMS for each is possible?
