LayerDrawingOptions
1785
6
12-28-2011 05:48 AM
RobertScheitlin__GISP
I have a question about the LayerDrawingOptions. When I set a desired renderer for a particular layer in a map service it works great but many of the layers I do not specify new renderers for do not draw using their default renderer or do not draw at all. Is this the designed behavior?
DasaPaddock
No, the other layers should still draw using the renderer they were authored with. Can you reproduce this using a service at: http://servicesbeta4.esri.com/arcgis/rest/services
Dasa,
   I can not get the sample (ChangeLayerDrawingOptions.mxml) to work at all with that MapService... I at least got it to change the renderer for 3 layers using my ArcGIS 10.1 b2 server.
BjornSvensson
Esri Alum
Please try again. The service had some hiccup...
Bjorn,
   Now I see it working. Now to see if my server has some huccup too...
PaulHastings1
Bjorn,
can i dredge up this old thread?
i'm seeing the same behavior. i can fiddle w/the example map service just fine but our local one's returning a NULL layerDrawingOptions array. that map service also has a feature service as well. could that be the fly in this ointment? if so, any workarounds?
thanks.
PaulHastings1
nevermind...Service must report "Supports Dynamic Layers: true".
